![]() | Home > Maintenance & Mods (L322) > Did Halfords recommend the wrong Oil??? |
The ACEC numbers in the small print is the thing to follow... It needs to meet these criteria NO MATTER WHAT!
Clarky4.4tdv8 Member Since: 16 Jul 2022 Location: Nottingham Posts: 4 ![]() ![]() ![]() |
Thanks, I will try and locate them |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4321 ![]() ![]() ![]() |
Has to be WSS-M2C934-B spec for my 2011 4.4 TDV8 fitted with a DPF.
Page 219 of Owners Handbook
Thanks DrRob… I don’t have all the individual codes to hand… 👍 |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Also known as STJLR.03.5005. 2015 Range Rover Autobiography 4.4 SDV8 |
Doesn't look like the correct oil to me. Looks like it's the oil for the 3.6 TDV8 and 4.4 TDV8 *without DPF* (all UK 4.4 TDV8 cars are DPF) that comes up (STJLR.03.5003). You need 5005. I'm not aware Halfords sell the correct oil. Euro Car Parts will. And if buying online, Advanced Factors and Opie Oils have the correct oils. Smith & Allan are very popular among 4.4 TDV8 users and I personally buy PETRONAS Syntium 5000 FJ 5W-30. You mentioned you want to do your own service. It is EASY on the 4.4 TDV8 and will take you no longer than an hour. You need a bucket, flat blade screwdriver, M8 spanner, 36mm socket with small torque wrench for the oil filter and a funnel. You also need a strap wrench if changing the fuel filter. You need: 10L Oil STJLR.03.5005 LR022896 OX153/7D2 Mahle Element Oil Filter LR011593 (x2) Air filter LR032199 Pollen filter LR072610 KC521 Mahle Fuel Filter LR0290 No parts needed but be sure to clean the MAP sensor (1x T20 screw on the "donut") Lithium grease spray all hinges Here's a guide I wrote for changing the oil via the drop method: https://www.fullfatrr.com/forum/topic60560.html Sam has also done a video on servicing the 4.4 TDV8: Advanced Factors (a site sponsor) can supply you all the parts you need at very competitive prices. 2015 Range Rover Autobiography 4.4 SDV8 Last edited by garyRR on 4th Sep 2022 12:45pm. Edited 7 times in total |
But when ordering from ECP you will need to speak to their operative on the phone, like they are 3yrs old, checking 5 times it’s for the correct grade of oil! And again when it’s delivered!
With ECP Online you can specify the ACEC and Ford spec as filter options and it only give you one choice for the TDV8 4.4 which is the Shell Helix ultra at £70. You can get the correct spec oil for 1/2 that at other suppliers. If it says C1 it's the right stuff. 2012 TDV8 Vogue (L322) |
LT Member Since: 13 Mar 2017 Location: South West Posts: 402 ![]() ![]() ![]() |
I’m a convert to a Smith & Allan thanks to this and Martins other LR forums:
QuebecTango Member Since: 06 Jan 2019 Location: Brighton Posts: 55 ![]() ![]() ![]() |
I’m also a convert to Smith & Allen, very good service and price. They are a Shell agent so it’s possible that their own brand is Shell but don’t know this for sure.
Thanks for this, very helpful indeed |
