Home > Maintenance & Mods (L405) > Kick Plate Removal |
batmanreturns Member Since: 16 Jan 2017 Location: Wiltshire Posts: 56 |
nudge! anyone able to help? Can't find anything online or via youtube etc thanks |
1st Sep 2022 10:56am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35425 |
i believe they prise upwards.. ... - .- -.
1st Sep 2022 11:06am |
thanks, i think they do but it's the removal of the plastic trims that semi sit opn top of them, it looks like you need to remove these prior? |
1st Sep 2022 12:04pm |
.....and if so how? thanks |
those bits that slightly cover the tread palates are just push fitted... ... - .- -.
1st Sep 2022 12:49pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Pull the top of the lower half of the B pillar trim towards the seat using a trim tool, then when it's all popped off, lift it off the lower plastic B pillar cover... Then you can simply pull the lower foot-shaped panel upwards and it should just come out... Then you can see your sill panels and their wiring... The fronts are self-explanatory, the rears however may need the rear cover panel removed? This simply pulls towards the front of the car, with two fixing poppers |
2nd Sep 2022 10:41am |
