![]() | Home > Maintenance & Mods (L322) > Rear washer leak repair - the cheaper option! |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 596 ![]() ![]() ![]() |
I've repaired the rear wiper motor twice. Lots of rust in it but had it thoroughly cleaned, painted and lubed. New cogwheel and new seal. Failed within a few months, every time. The water pathway design, as elegant as it may be, is a liability.
Eddthedoc Member Since: 07 Jan 2024 Location: Norfolk Posts: 8 ![]() ![]() ![]() |
A huge thank you from me too alanm_3. Repair worked perfectly and didn’t need to take the spoiler off either.
TheDoctor Member Since: 08 Sep 2024 Location: Hampshire Posts: 1 ![]() ![]() ![]() |
I just tapped my banjo out without drilling. Using the body of a socket screwdriver. The plastic is soft enough to pop the 4 'rivets' through the holes easily. No need to drill if you don't want to.
