![]() | Home > Maintenance & Mods (L322) > Tow wiring |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
Not sure about the year changes but if you find one you will have to go into the ccf file and tell the car you have wiring, otherwise, if you have rear parking sensors they will keep beeping when you select reverse. Over in the UK, we have to tell the car whether it's 7 pins or 13-pin electrics, they split into two sockets for 7 pins. and 1 socket for 13 pin. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1544 ![]() ![]() |
It's odd yours doesn't have the towbar. A friend who worked for LR in Oz said all AU-delivered cars came with one.
Must be plug and play then |
Joiner Member Since: 01 Sep 2022 Location: Melbourne Posts: 20 ![]() ![]() ![]() |
Definitely no electrics or towball.
Have a read here I know its a later car but may help someone else
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
As it's an earlier car, you'll also need to check if you have the tow ECU or not. If you don't, try and find a loom with a tow ECU. If not, you'll need to splice a 7 pin into the cabling at the rear fuse box. 2015 Range Rover Autobiography 4.4 SDV8 |
Yep, most wiring kits seem to come with the ECU.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
As every Australian market L322 should have a tow bar and electrics it can't be that hard to find one in a wreckers, BMW x5`s of the same era have the same part. Then the fun begins as on both my Oz cars I have had to rewire the socket to Oz spec, both have been wrong and UK spec. Things get worse if your trailer has LED lights as most do, you will then have to overcome the constant flashing, this can be done with relays and load resistors, quite complex but I managed to make a plug-in box. I think there is a company that will sell you one. 2007 TDV8 VSE
Managed to find all the wiring and control.
Re trailer LEDs, I was going to build one (I was once an electronics tech) but saw one of Labtronx units on AULRO for a price I couldn’t resist…
My caravan is old school, no LEDs anywhere. So no issue with that.
By default the car is set up to be 'on' for 7 pin. Only need to change the CCF according to the loom and socket you have.
So,
