Home > Technical (L322) > Brake Master Cylinder LR012901 - Impossible to find
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
So my 2010 TDV8 4.4 needs a new brake master cylinder and I have tried all the main supply sources including Advanced Factors and for some reason they cannot source or even pre order the part.
If anyone knows of a source do let me know, used is fine. The LHD version (LR012900) seems to be easy to get, not sure if it could be modded to work on a RHD) but by car is stuck in a car park and cannot move until I get the brake cylinder done. I really hope it won't be weeks or longer........
I am also trying breakers, but if anyone has any advice or alternative options that would be much appreciated. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #641513 31st Aug 2022 8:45am
garyRR
TRW manufacturer one (who were OEM anyway). Available new from stock.
The TRW part number you're looking for is PMF519. They're about £125.
AutoDoc have them in stock. 2015 Range Rover Autobiography 4.4 SDV8
Post #641523 31st Aug 2022 9:20am
What's wrong with yours? Could it not be rebuilt..? I've not googled but you would think someone is doing it... they usually only need new seals... Thumbs Up Pete
Post #641527 31st Aug 2022 9:36am
Flashman
I am sure it can rebuilt but a straight swap makes things quicker for my mechanic as I need the car up and running asap.
Mechanic told me when he tried bleeding the brakes fluid was only getting to the rears and nothing to the fronts, even after checking hoses etc. Tom
Current Drive
Previous Drives
Post #641530 31st Aug 2022 9:50am
mjdronfield
Yeah, garage struggled to bleed mine and ended up changing master cylinder… rightly or wrongly….
Looked at my paperwork to see if part number was the same, and it was, so can’t help with alternatives I’m afraid.
Though rebuild might be possible, as others have said.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #641543 31st Aug 2022 11:21am
Flashman
I managed to get a master cylinder with booster and reservoir complete from 2012 TDV8 from a breakers as I need to be able to use the car. I am guessing they are normally reliable so worth a shot.
I found that if you search for the booster it is easier to find used as the cylinders don't seem to have part numbers on them.
So you can search for: AH42-2B195-BA
Might be useful to anyone else hunting around. Tom
Current Drive
Previous Drives
Post #641575 31st Aug 2022 5:51pm
