Home > Maintenance & Mods (L322) > Brake Caliper refurbish recommendations
Andy2986
United Kingdom 2011 Range Rover Vogue TDV8 Barolo Black
Hi,
Ive finally managed to get a complete second hand (front and rear) set of calipers for my 4.4TDV8.
I would like to have them rebuilt and powder coated.
Can anyone recommend a place that can do this for me ?
Ive found a few places on line but before I send them off thought i would ask here.
Andy 2011 4.4 TDV8
2000 4.6 P38
1998 D1 300tdi
Post #639730 15th Aug 2022 6:20pm
garyRR
The place I'm aware of online are BCS Automotive however, iirc it's around £250-300 per caliper for a refurbishment of the front Brembos (and Maltings sell brand new reproductions for a smidge over £300 on next day delivery anyway).
Fronts
Local engineering firms would also be able to do the refurb for you - at the end of the day it's 6 pistons and seals, plus two bleed screws per caliper, plus a shot blast and powder coat. If you shop around, I imagine a workshop may do it for about £400 a pair. You'll need to ring round a few engineering firms because they're the kind of places that don't have websites and work old school.
Warning, do not attempt to remove the bleed valves yourself. They're notorious for welding themselves to the cast and require proper extraction / drilling in a workshop. Trying to remove yourself will most likely result in snapping them.
Rears
The rear calipers are super simple to refurb. The kit is about £15 and getting the single piston out only requires a basic air compressor (your typical Ring compressor for filling your tyres is more than powerful enough). These shouldn't cost more than £100-125 each to get refurbished. But, the original manufacturer are TRW and brand new OEM calipers can often be found on offer for £90-100 each (I bought 2x brand new TRW rears for £85 each)
So, my advice is even though you've got hold of a full 2nd hand set, I'd weigh up the options and costs before diving in! 2015 Range Rover Autobiography 4.4 SDV8
Post #639733 15th Aug 2022 7:14pm
Andy2986
I saw the Maltings callipers but if I’m honest was worried that they wouldn’t be up to OEM standard.
It’s more the powder coating I’m after. But with a service included. 2011 4.4 TDV8
2000 4.6 P38
1998 D1 300tdi
Post #639736 15th Aug 2022 7:34pm
garyRR
The rear calipers are notorious for seizing so, would be best they're new or have a full refurb. Like I say, the refurb kit isn't expensive so, is no big deal.
The Brembos aren't known so much for seized pistons but the bleed valves do weld themselves together, which is going to cause a big problem when they get fitted and the garage can't bleed the caliper so, a screw extraction, strip and powder coat would be the most likely minimum. Also, getting one bleed valve open isn't enough. These calipers are very difficult to bleed properly and need both valves open.
Most engineering workshops or fabrication workshop will do power coating so, you'll be bound to have several nearby to where you live. 2015 Range Rover Autobiography 4.4 SDV8
Post #639738 15th Aug 2022 7:45pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
https://www.biggred.co.uk/
These guys refurbed the callipers for my RX8 and did a great job for about £250 (couple of years ago so prices may have changed) 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #639800 16th Aug 2022 11:29am
dhallworth
They're very easy to do yourself.
You can buy refurb kits on eBay with new pistons and new seals and you can also buy high temperature brake caliper paint.
I've just done the 4 pots on my car and am more then happy with the results.
If you don't need the pistons and seals you can clean them gently with a wire brush, and I mean gently as you'll mark the calipers if you apply much pressure.
I then built up 3 coats of paint on mine and then applied the transfers.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #639807 16th Aug 2022 11:56am
Andy2986
Wow they look great !
Did you lacquer that as well ? 2011 4.4 TDV8
2000 4.6 P38
1998 D1 300tdi
Post #639942 17th Aug 2022 2:14pm
dhallworth
No, that’s just the finish that came from the can.
https://techniqpro.com/product/techniq-thu...mperature/
That’s the paint that I used.
I’m going to PPF the calipers as per Craigs advice before I start using the car again though. Smile
Post #639947 17th Aug 2022 3:30pm
beemer5711
Wales
They look mega!
Post #641281 29th Aug 2022 7:39am
Callipers are a great way to start doing you own DIY, if you find it's too much then just send them to one of the places refurbishing them...
This is for the fronts on the early L322, very similar to most callipers so the process is similar...
https://www.fullfatrr.com/forum/topic31282.html Pete
Post #641299 29th Aug 2022 10:04am
Phoenix
David.
PPF?
I assume the decals are just one of the many fleabay offerings?
Mine are looking a bit road-weary so it's on the list of cosmetic jobs, I'm thinking of doing 'something' with the rear calipers and carriers, maybe the same colour but without the stickers...
Post #641348 29th Aug 2022 4:37pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I've had to order the Maltings front 6 pot callipers as I have some seized pistons. I will then refurbish the old ones once off the car.
The Maltings ones seem to be copy castings of the Brembo ones without any branding but are certainly heavy and solid. If I have any issues I will update. New genuine front callipers seem to be around £1k per side which is nuts! Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #641370 29th Aug 2022 6:37pm
kevinp
Hi Flashman, interested in how you discovered you had some seized pistons.
Post #641381 29th Aug 2022 8:05pm
Flashman
The car I bought had been standing for a while during Covid and there was a serious vibration through the steering when braking. The front discs were seriously rusted and when I looked to change the front pads I found that only 2 of the 3 pistons was pressing against the pads causing serious vibration issues. To be safe I am just replacing with the Maltings ones so I can drive it, and will then look to referring the original Brembo ones to put back on the car in the future.
Like many have said, the rears can stick, and my rear drivers side did when I picked it up, but since driving it for a few miles it has released and does not rub at the moment. Touch wood! Tom
Current Drive
Previous Drives
Post #641382 29th Aug 2022 8:17pm
PlaceDuPilori
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
Hi Tom - slightly older thread I know. How did you get on with the Maltings callipers in the end?
Post #684617 2nd Feb 2024 1:24pm
