![]() | Home > Technical (L405) > Kph Speedo |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
Hey El Cid,
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7974 ![]() ![]() ![]() |
Mine will only change the small digital speed readout to KPH, the numbers around the outside of the dial always stay MPH.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8684 ![]() ![]() ![]() |
Mine can swap the main dial as well as the digital readout on a MY16. Must have been an update at some point. There is nothing that can't be fixed with a hammerππ
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 239 ![]() ![]() ![]() |
Mine allows both. Might be a π¨π¦ or North American setting. Dan. π¨π¦ 2013 L405 5.0 SCV8 |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1042 ![]() ![]() ![]() |
I have a 16 MY too, and can get both, as above. |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1245 ![]() ![]() |
Iβm not sure if applicable , but at one point , the lamps needed a physical switch pushing. Could be found by each headlight.. My car in 2007 was left and right The next was 2012 was push , and it sprang back , so you had no idea if it was for the U.K. or the eu ![]() 2016 was electronic & on the dash menu. Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc He who dies with the most toys wins... |
