Home > Technical (L322) > Cable routing
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
Cable routing
Just wondered… if I wanted to pass a bunch of cables through from the cabin to the engine bay, is there a ready made route I can use?
[I wish the mobile site allowed post editing!] Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #641143 27th Aug 2022 9:20pm
garyRR
I'm pretty sure there's a point behind the glove box leading to the battery.
Don't quote me on that but take a look. 2015 Range Rover Autobiography 4.4 SDV8
Post #641174 28th Aug 2022 7:18am
tymh
Thanks Gary. Will do. Tym
Post #641175 28th Aug 2022 7:19am
p38arover
Australia
Yep. I ran the coax and power cable for my UHF radio through that grommet. I snaked a well lubed piece of 1.6mm welding rod through first and used it to pull through the coax and figure-8 power cable. I can't remember if I had to remove the end piece of the dash that holds the cup holder to get access to the welding rod after it came through or just the end closing panel. It was some years ago. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #641202 28th Aug 2022 10:28am
tymh
Thanks p38
I have the 2008 novel so no cup holders and the welcome light is in the glove box door, not the end panel. I’ll have a root around there when I do the headlight work. Tym
Post #641204 28th Aug 2022 10:58am
garyRR
Just drop the glove box down and open the bonnet and you should find a route.
If needed, remove the side panel on the dash (look at my dash cam install guide as not to damage it). 2015 Range Rover Autobiography 4.4 SDV8
Post #641205 28th Aug 2022 11:00am
tymh
Removed Tym
Post #641267 28th Aug 2022 10:07pm
tymh
Thanks Gary. You seem to have the same set up as I do. I found the huge boot that, worst comes to worst, I can cut and silicone around the wires, but can’t get to the cabin side.
I need to remove the end panel but while I can get to one screw, I need to remove the air vent to get to the second one.
How do I remove the vent? I tried unsuccessfully as Ididn’t want it break it! Tym
Post #641268 28th Aug 2022 10:07pm
tymh
Post duplicated. Can’t find delete! Tym
Post #641269 28th Aug 2022 10:10pm
