Home > Technical (L405) > Deployable side steps - is this strange... |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1703 |
Hi all,
28th Aug 2022 6:53am |
Thanks for confirming Vogue.
28th Aug 2022 7:15am |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
I double lock my car. When I return and unlock on the fob, both steps deploy on unlocking. Is this what you've got. 2017 5.0 Autobiography Supercharged
28th Aug 2022 7:19am |
Not really V8,
28th Aug 2022 7:48am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1192 |
It's a good indication that you have not Locked the car mine do as yours retract after leaving(door`s close) but then deploy until I lock the car. |
28th Aug 2022 8:49am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3752 |
Just to make you aware, most Main-agents try to wriggle out of Warranty claims (particularly extended warranty claims) on Deployable sidesteps if they were fitted as a dealer fit accessory. The only way they will entertain a claim is if they came fitted with them as a Factory option and they usually want to see the original invoice to prove they were not dealer fitted. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
28th Aug 2022 11:17am |
Typical - considering I'm not the original owner I would have no idea if they were fitted from the factory - And I doubt I can find out..! I didn't buy the car from a main agent and the car came with an 'all inclusive 12 month RAC warranty - including wear and tear'... We'll see how that goes when I walk to them about it. Thanks again Vogue Ash ------------------------------------------------------ 2016 SDV8 AB |
28th Aug 2022 11:30am |
Olders Member Since: 17 Mar 2011 Location: Suffolk Posts: 115 |
Hi, I have exactly the same issue on my 2016 AB. If I leave the car unlocked, the side steps will deploy after approx. 10 mins (doesn’t happen when locked). I too thought it was a fault but I have now done quite a lot of digging on this and can confirm it is normal operation on 2016 cars (I think ‘14 & ‘15 as well). I believe the thought process is that it provides a visual indicator that you have forgotten to lock the car. They changed this on (I think) 2017MY onwards - possibly 2019 onwards. I have had this confirmed by both my local independent (who is very knowledgeable and did his own investigations into the matter to confirm it) and from first hand evidence: I have two friends with the same age vehicles and it is exactly the same on theirs, another with a 2019 car does not have the same functionality. I am pretty certain this is correct info. Cheers. ----------------------------------------------- 2016MY FFRR 4.4 SDV8 Autobiography Loire Blue 2007MY FFRR 3.6 TDV8 Vogue SE Tonga Green |
6th Oct 2022 5:18pm |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 96 |
My MY 14 steps stay up once I close the door, irrespective if locked or not.
7th Oct 2022 11:19am |
