Home > Technical (L322) > Forced DPF Regeneration using Gap iid.
Page 4 of 6 <123456>
Cheers Mike, just concerned with what may happen if at around 30,000 miles (from the amount of regens) someone has gutted the DPF and I force a regen...!!
I have a friend who does remapping, I will get him to download my software and see if anything has been mapped out or modified, it might give a clue...
In the meantime I have the IID in the glove box so I guess I can do a forced one if it faults...
Cheers Pete
Post #640896 25th Aug 2022 8:36pm
JayGee wrote:
I’d avoid a forced regen unless you absolutely have to as it generates a lot of heat and stress on components. It really should be a last resort to fix a blocked DPF.
After a moment of reflection, I'm with you on that one Thumbs Up Pete
Post #640897 25th Aug 2022 8:38pm
Baltic Blue
Pete,
On reflection,
Forced regens are really only a last resort to be used if you get a red alert visit dealer type of message.
If it is running fine and returning 30+ mpg, then hold off for a while .
You would be able to see sleeves either end of the DPF if it has been off for any reason., but I have no idea about mapping.
I do know that it is an automatic MOT fail if they think it has been tampered with in any way.
Post #640906 25th Aug 2022 9:38pm
DrRob
Post some pictures of your DPF Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #640908 25th Aug 2022 9:41pm
Thanks Mike and Rob, I will have a look at it next week when it gets on a ramp, not sure if I will post any "evidence" on here though... Rolling with laughter Pete
Post #640916 25th Aug 2022 10:18pm
DrRob
Fair point Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #640926 26th Aug 2022 7:20am
JayGee
If the DPF has been gutted there would be no pressure differential across it and thus it would show zero g soot load. A new or clean DPF will flow more exhaust gas at a higher pressure differential than an old and partially ash filled one so again the point at which it needs to initiate a regeneration may be higher. Just drive and monitor it and only worry if you get warning lights. 2012 TDV8 Vogue (L322)
Post #640929 26th Aug 2022 8:37am
Yep, it just goes to show how a diagnostic tool can be a two edge sword... Plug it in and maybe you will learn more than you want to...!!!
It's not giving any warnings, it does over 30mpg in normal driving and pulls well and cleanly... I don't think I will do anything until fatty tells me otherwise.... Thumbs Up Pete
Post #640984 26th Aug 2022 6:15pm
DrRob
Good plan. Use the IID when you need it not when you think you need it Thumbs Up Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #640985 26th Aug 2022 6:25pm
Gremlin500
…………. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #640988 26th Aug 2022 7:02pm
JayGee
Zero chance of crankshaft failure on the V8 2012 TDV8 Vogue (L322)
Post #640991 26th Aug 2022 7:10pm
Gremlin500
Post #641007 26th Aug 2022 8:32pm
I am putting the IID down and walking away..........!!!!!!!!! Bow down Ner Ner Pete
Post #641018 26th Aug 2022 11:28pm
Gremlin500
Post #641021 27th Aug 2022 12:01am
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Gap11 Update
Even so I think it good to know that the gap tool update has been made available now thanks to these postings. New to range rover’s and after a few replacements of sensors, rightly or not, it gives hope to a new owner. I learnt that a decent run will sort things out. Had mine for 5 years now but needed to take such a drive three weeks ago after the dreaded yellow warning! Thumbs Up Thumbs Up
Tool updated this morning thanks to everyone's posts here and will plug into the FFRR asap to check it out!
Thumbs Up Dave
Post #641040 27th Aug 2022 10:02am
