Home > Technical (L322) > Reduced performance DPF filter full.
Page 4 of 5 <12345>
DrRob
I'm talking about inlet manifolds not plenum as per Gary's comment Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #640609 23rd Aug 2022 1:00pm
JayGee
Embarassed Embarassed Embarassed Embarassed 2012 TDV8 Vogue (L322)
Post #640610 23rd Aug 2022 1:02pm
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
More "Restricted Performance"
I have had several instances recently where the "Restricted Performance" warning has come up which then clears when the engine is shut down and then restarted after a bit. There are no faults showing on the IID tool, apart from the P040 EGR Sensor A which they all seem to have. The DPF is not full.
I have already had all 4 short hoses on the plenum replaced some time ago as a preventive measure. On removing the plastic engine cover the only thing which seems unusual is that I can get a bit of movement on the hose junction marked in red. Could there be an air leak here which is causing the problem? It is not secured by a normal jubilee clip, so there does not seem to be a way of tightening it.
Any suggestions would be appreciated.
 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #640822 25th Aug 2022 9:38am
JayGee
That joint is always loose and can't be tightened as the elbow is rigid plastic. If there is a leak from the interior sealing lip you will see oily gunk around the elbow. 2012 TDV8 Vogue (L322)
Post #640824 25th Aug 2022 9:48am
DrRob
I replaced the whole thing on mine as part of my preventative maintenance program. Old one was a bit sooty.
Took 5 mins.
You can take that spring clip off, squeeze it and then refit. Some folks have also used PTFE to make a tighter seal inside for the green seal.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #640830 25th Aug 2022 10:13am
garyRR
Re: More "Restricted Performance"
This is well known for failing - a poor design in my opinion.
Inside the plastic pipe is a double lipped rubber seal, which isn't really substantial enough. Over time this collapses in places and leads to intake leaks.
Here's a photo with some sections collapsed highlighted:
There's 2 options:
1 - buy the replacement part. It's £170 and permanently solves the issue. Takes 5 minutes to fit.
2 - buy some gas specification PTFE tape (about 80p) from Screwfix/Toolstation, wrap it around the throttle body then re-fit the pipe. This is what I have done (for now) and 1,500 miles later, is working fine. I can't say how long it will last obviously but, a good and cheap interim fix / diagnostic before splashing out £170.
 2015 Range Rover Autobiography 4.4 SDV8
Post #640842 25th Aug 2022 11:25am
scuddriver
That is most helpful - thank you.
Do you have any tips about removing/ refitting the metal clips that hold it in place? 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #640854 25th Aug 2022 3:05pm
JayGee
it just flips out with a screwdriver but hold it as it can spring out and into some unreachable crevice in the engine.....
Be extra, extra careful with the connector in the bottom right of your picture as it can snap even if you look at it the wrong way. 2012 TDV8 Vogue (L322)
Post #640857 25th Aug 2022 3:31pm
SETDV8
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Thought I'd post an update.
The new inlet manifold is expected at Land Rover on 6 October so I'm hoping to have the car back by the middle of the month.
Cheers,
Steve.
Post #644370 30th Sep 2022 8:13am
scuddriver
I keep getting the "restricted performance" warning which occurred again yesterday but with no "limp home" mode. Thid usually clears when the engine is stopped for a while and restarted.
When I got back I left the engine running and plugged in my IID reader. It came up with 3 engine ECU faults.
the one which clearly triggered the warning was the P0105-16 manifold absolute pressure/barometric circuit general electrical failure. On clearing the faults the "restricted performance" warning disappeared. the P040D one of course recurred.
Has anyone experienced this P0105 fault or know how to deal with it?
 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #644991 7th Oct 2022 10:42am
JayGee
I had the map sensor fault once when I removed it for cleaning and didn’t plug in the connector properly so check that. MAP sensors are not expensive so maybe just change it. 2012 TDV8 Vogue (L322)
Post #644992 7th Oct 2022 10:49am
Baltic Blue
You should try cleaning the MAPT (manifold absolute pressure and temperature ) sensor.
5 Minutes job, I use spray brake cleaner.
It’s the sensor in the plenum .
Post #644994 7th Oct 2022 11:00am
JayGee
Mine was totally blocked with soot and oil paste but still kind of worked so not sure this would throw a code. Cleaning it IME just gives you a crisper throttle response as it can react more quickly the pressure variations. Should be cleaned every 6 months or thereabouts. 2012 TDV8 Vogue (L322)
Post #644996 7th Oct 2022 11:41am
scuddriver
thanks Guys,
A 5 minute job as you said. My sensor was caked in soot, but brake cleaner did the job.
 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #645000 7th Oct 2022 12:13pm
JayGee
That looks clean - this is when it's bad (but still not throwing a code).
Post #645009 7th Oct 2022 1:21pm
Page 4 of 5 <12345>
