![]() | Home > Technical (L322) > 4.4 restricted performance |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
That to me would point to a failed temperature sensor on the left hand exhaust manifold. It's quite common for these to fail, which is what would increase my confidence in thinking it is that. 2015 Range Rover Autobiography 4.4 SDV8 |
JoshVogue94 Member Since: 18 Aug 2022 Location: RCT Posts: 56 ![]() ![]() ![]() |
I've tried viewing the live data using icarsoft and the temperature for all the sensors is showing 100 degrees even when the car is cold which is throwing me off as to which one it could be |
00 should indicate left bank.
I'll try disconnecting the battery tomorrow thanks mate. I did change the oil cooler as it had a bad oil leak and disconnected the temp sensor without disconnecting the battery so wondering if that's what has caused it as I never had the problem before that. |
100 degrees is the low value coded into the ECM, you need to get the exhaust warm to evaluate if they're reading correctly.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I had the similar p0040d code, for near side exhaust sensor. I was confident it was not allowing a DPF regen,. I measured the sensors internal resistance, it was open circuit. Ordered a new one, and then found I couldn’t get the old retaining nut off, after destroying old sensor. Plugged new sensor, loosely to loom, and cleared the code… presto. But the sensor although tests ok at cold, wouldn’t ever ‘get hot', and hence still no DPF regen. So I removed it from loom, took indoors, heated up sensor, measured it’s resistance. When red hot on gas stove, it went no lower than 650 ohms. Therefore, if I connected a resistor on old broken sensor wiring plug, of 650 ohms, the car would see an acceptable reading (650 ohms) and throw no code, but would actually see a ‘hot sensor’, and coupled with the other needed factors, to allow a DPF regeneration, (other temp sensor, and fuel tank over 1/4 and speed over 30mph, it could trigger a regen. Problem solved. Car ok, DPF regens occurring when needed, new resistor from eBay about a £1. For ten! New sensor not needed! |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1281 ![]() ![]() ![]() |
You guys are very clever. If I can't fix it with a spanner I'm |
