![]() | Home > Maintenance & Mods (L322) > Any instructions on how to adjust bonnet and latches? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8568 ![]() ![]() ![]() |
There are two rubber stoppers that screw into the top of the slam panel, you use these and the bonnet latches, there is a locknut that you spin down to allow adjustment on the latches, put a spanner through the spring to spin it, then the rubber stoppers give you the height of the bonnet and the catches are then adjusted with a slotted screwdriver in the pointed end so they latch when the bonnet is shut, it's just a matter of adjusting one and see what happens, it doesn't take much to get it sorted once all is lose and easy to move... |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
Thank you.
Excellent, it a very satisfying job... |
...that main dealer should have done for me!
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Main dealers. A disgrace.
The job would have most likely been SC'd to a bodyshop, usually the one the insurance co. designates, the dealer would just be the customer interface. |
The bodyshop was the main dealer's bodyshop, part of the firm. 2015 Range Rover Autobiography 4.4 SDV8 |
Oh, well in that case,
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 124 ![]() ![]() ![]() |
I found I had a weird humming sound at 130km/hcomming from the hood
My bonnet latches are all sorted now.
I only mentioned them because they are part of the laching efficiency and must be properly compressed to be efficient.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1310 ![]() ![]() ![]() |
