Home > Maintenance & Mods (L322) > Rear occasional knocking over bumps |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
I’ve noticed a knocking / rattling noise from the rear when hitting bumps. Not every time, but enough to annoy me… especially as I replaced the bushes a year ago, and less then 10,000 miles.
21st Aug 2022 12:30pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
There are lots of other bushes at the back apart from the wishbone, the hub upper and lower bushes are known to fail regularly....
21st Aug 2022 12:48pm |
Cheers Pete.
21st Aug 2022 1:01pm |
Ah, I see, get an MOT garage to look at it for you, they are good at exposing weakness in bushes... Pete
21st Aug 2022 1:03pm |
Ashley Member Since: 28 May 2020 Location: Bromley Posts: 30 |
I had similar and was the heat shield above the rear exhaust ,fitting larger washers on cured the fault. |
21st Aug 2022 1:38pm |
I was thinking something like that too… a ramp and big bars would help! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
21st Aug 2022 4:31pm |
Good shout. I’ll get under again just to make sure there isn’t anything else loose. I’d be annoyed if I re-replaced the bushes only to find the noise is still there Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
21st Aug 2022 4:33pm |
