![]() | Home > Technical (L322) > Reduced performance DPF filter full. |
SETDV8 Member Since: 30 Apr 2022 Location: Kent Posts: 20 ![]() ![]() ![]() |
Kevinp and Jay Gee, I've got my glad rags on now so will have a look tomorrow.
Thanks Gary, hope you're right. |
Update from today.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
It did hint at a split manifold from your original symptoms....hope you get one delivered soon |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
There's one on ebay, but in Lithuania if you need it 'quicker'.
Thanks Rob, I take your point.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1481 ![]() ![]() |
I'm pretty confident they're regularly in stock. I may be kidding myself but I think I saw Maltings had 2 last week which are sold now. Probably just a case of waiting a week or two for the next warehouse delivery. I'm not sure where they're made or who makes them for Land Rover.
Cheers Gary |
Gary, you thinking of the plenum chamber and not the inlet manifold? Doubt you could do the inlet manifold in that time. |
Definitely the inlet manifold. It's not overly difficult. To remove and replace when you've done a few before. 2015 Range Rover Autobiography 4.4 SDV8 |
That's fair enough mate. Think it took me longer than that to just take the plenum off!! I suppose if you've done it once then it is quicker next time. |
Plenum is 2 minutes when you've done it umpteen times 😉 2015 Range Rover Autobiography 4.4 SDV8 |
Sounds like it takes a lot shorter time to do the inlet manifolds on a 4.4 tdv8 than a 3.6? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
They can be repaired by a line of rivets or self tapping screws along the seam. 2012 TDV8 Vogue (L322) |
