![]() | Home > Maintenance & Mods (L322) > Air Con - Diagnosis... |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 394 ![]() ![]() ![]() |
After having my Air Con 'tested' and refilled by Kwik Fit a month ago, it recently started to blow out hot air again. So I booked it in with my local Air Con Specialist. He has had a look - there was some dye in the system. After plugging in his machine he found a leak at the bottom corner of the condenser. There was only 5 bar pressure in the system but that was recovered anyway.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
Did you use the discount code on check out?
Damm, I missed that. Just ran it through again and the 5% would've given me £6.25 off. Will bear that in mind next order, thanks. Gavin 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics |
So, I've stripped down the front, took off the air con pipes, removed the slam panel and I cant get the condensor to lift up and away. It rises about 1cm and that's it. Just stops. I've looked and looked but cant see any clips holding it in on either side. It is literally just sitting there in the slot..
So, just finished. Its out and the new one is in place.
No problem David. After getting the old one out I still couldn't see why it wouldn't come out - no clips on the plastic pack keeping it in |
