Home > Technical (L322) > What Allen key for OEM roof rail bolts?
lodelanelad
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Santorini Black
I have managed to get a set of bars and bolts but I can't find the Allen key that fits the bolt? It is a hexagon (not a star) with a small hole in the middle - about 6mm across. Does anyone know what it is called or where I can source one? Thanks
Post #639847 16th Aug 2022 4:34pm
rjff
This gives you the idea and goes up to 6mm.
https://www.toolstation.com/draper-security-bit-set/p52910
Search others from this idea if you feel you need larger or perhaps more durable.
HTH Cheers
Richard
Gap IIDBT
Post #639858 16th Aug 2022 5:22pm
lodelanelad
Perfect - thankyou
Post #639860 16th Aug 2022 5:30pm
