Home > Technical (L322) > Hawkeye code reader
JT
England 2006 Range Rover Vogue 4.4 V8 Tonga Green
Hawkeye code reader
Any help appreciated. I recently have acquired a discovery 2. i thought i would clear the fault codes using my hawkeye. i had to put in my unlock code for this but it said i had the wrong version code. silly me forgot to take a note of the rangerover unlock code but had a written down code from when i purchased it. it too now says i have the wrong version code. I had my hawkeye upgraded from omnitec to version 7 from 5 but cannot remember getting new version unlock codes. Does anyone know which part of the unlock code corresponds to the different versions as Omnitec are no longer available. cheers John
Post #639409 12th Aug 2022 1:17pm
Shaunj69
England 2012 Range Rover Autobiography 4.4 V8 Zambezi Silver
And just to add insult to injury Bearmark are no longer supporting it Sad
Post #639410 12th Aug 2022 1:34pm
JT
I know !!! had no joy from Bearmach or the company that bought out omnitec. I just need to try and work out the code or maybe some how downgrade to version 5.
Post #639575 14th Aug 2022 2:01pm
Gsxr1250dave
What is it your trying todo fault wise ?
Post #639595 14th Aug 2022 5:40pm
JT
Hi. I am trying to reset the door opening so all doors open on one press of the key fob. Tried disconnecting the battery but the factory reset is one press of key fob opens drivers door 2 presses open rest of doors and 3rd press opens rear door(what a faff)
Post #639683 15th Aug 2022 11:14am
Gsxr1250dave
Iv got an unlocked hawkeye I used on my D2 and others I'm sure it should work on yours your not a million miles away. Got a few family things going on at the moment but if you don't sort it drop me a pm in a couple of weeks and I see if I can help
Post #639713 15th Aug 2022 3:13pm
Weegie
I am in Hailsham. I have a Gap iiD which might read and clear your codes. Happy to try . John
GAP iiD BT
Post #639718 15th Aug 2022 3:58pm
JT
Hi John. would be great to give the gap tool a go. a go.
I am just out at Stunts green near Herstmonceux. my Phone number is 07984950840. text me so i can pop in to you at some point. Not in the next couple of days as I am in the process of changing the auto box oil and am waiting on some seals. cheers John
Post #639751 15th Aug 2022 9:17pm
JT
Hi John. Just bought another rangerover. I am having same problem with my Hawkeye. Rangerover code doesn’t work 😠. Do you still have your gap tool as would love to clear faults and find out why airbag light and Eml light is on. Text me on 07984950840 if you still have your tool and you don’t mind helping me out. Worth a few beers 🍻 cheers john
Post #704000 7th Nov 2024 5:51pm
