![]() | Home > Technical (L322) > Charging issue? 4.4TDV8 |
mezo Member Since: 13 Mar 2022 Location: Milton Keynes Posts: 22 ![]() ![]() ![]() |
I've done the starter solenoid mod and posted updated photos of my approach on the other thread:
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
So, this evening I took my battery out and cleaned all of the contact points in the battery bay with emery paper, wire brush and some contact cleaner. I also blasted all the push fit plugs in there with contact cleaner too (2 big ones on ECU, plus the BMS one on battery -ve terminal), then disconnected and reconnected each plug a few times to clean the surfaces. I was surprised how much corrosion was on some of the contacts, especially the copper ones in the junction boxes behind the battery.
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
What did you find? Any pictures? Also consider replacing the relays in the engine bay and for the air compressor. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
Sadly not mate. I was trying to get as much done as I could before it went dark and, seeing as I’d bothered to get the battery out, I figured just to do as much as I could in there with the time I had whilst I could still see what I was doing.
Thank you, do share your findings. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
Ok, an update on charging behaviours after a day of using the car for a few long journeys. I did two long runs this morning about 45 mins each way, plus a few other short journeys afterwards running some errands. I then did another long journey of an hour this eve. Graph from the day is below.
3 Month update;
I can also confirm that the erratic charging profile seems to be normal behaviour as within parameters as stated in the WM. I’ve added a screenshot of a typical day with multiple long journeys. You can see the charging V mostly in the mid-13s with occasional peaks up to 14V. Note, this graph shows data that is from a snapshot every 2 mins so is not a ‘constant view’. You can also see the third journey has much lower and more erratic voltages which is good example of why it was worrying. However, you will also see that when the car is parked, the V available is always about 12.5V which is both expected and ample to start the car.
Yes i suspect you are right wrt to charging.
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 ![]() ![]() ![]() |
I think it is the normal working of the BMS.
yeh agreed - mines been fine since i did the stater solenoid mod - but the charging goes up and down as posted. |
I stopped worrying about low voltage/drain, with the relay MOD the car starts regardless of SOC and feels sold and reliable.
I have read the thread about the starter relay and cable, but can't relate. My 4.4 TDV8 does start in every condition with original set-up. It starts with weak battery and strong batter, with -35 degrees and +35 degrees outside. So I'm not considering this mod until some problem with it comes up. Maybe I would, if it shortened cranking time, does it? In my opinion this car is cranking a little longer than other makes.
it will work until it wont anymore, then you have to replace the starter and consider the mod. Design is such it will arc and start then eventually fail due to poor contact/shoot. This leads to corroded contacts etc. A solid contact is always better in my mind and removes the weekness in the system. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
