Home > Maintenance & Mods (L322) > DAB & Intravee & iPod
Austin
England 2004 Range Rover Vogue Td6 Java Black
yeah i think that is the best way for the win.
Did you manage to hide all the boxes ok? and did the disc changer fit in the exact same place the old one did? and while i'm here!!....... was it just a case of plugging things in or dd each ainet device need its own switched and ignition supply? i'm no stranger to ICE but this is one car i didnt really want to mess with.......... that much!!
Post #63586 12th May 2011 1:04pm
dan_uk_1984
I've not got a changer yet. When I have the iPod sorted (waiting on a cable) I'll see whether I need to go for a changer or not. I suspect not - I also suspect I'll get one anyway!
Only the DAB unit needs power. Both the Intravee and KCA-420i run off the existing power for the old CD changer as they are so low consumption.
To use Intravee you must loose the original changer - this is the only downside to the setup, but then Alpine CD changers are 10 a penny.
As for it all fitting in, yes no problem, with the changer removed there is a decent space in the cubby box. Obv thats then where the iPod can live too. For me, only the Intravee lives in there, everything else is routed to the back of the car.
The most difficult part of the whole install is taking the glove box out, but that's a lot easier if you've done it before and know where all the clips and screws are etc.
Post #63598 12th May 2011 2:46pm
SteveMFr
Site Sponsor
dan_uk_1984 wrote:
Steve you're a star!!
Cool
I actually like some of Mr. Jobs' products. I hate the DRM bullship, tho.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #63693 12th May 2011 10:23pm
dan_uk_1984
Right, hooked the iPod up now so have 30GB of music storage on there Very Happy
The only downside is that anything over a few thou songs and it is a bit of a mission to search through. But I think that could be solved by using proper folder structure, rather than my 1000 hits of the 80's all in one.
Organised by album/artist I guess is the way to go.
Post #63942 14th May 2011 4:40pm
SteveMFr
Site Sponsor
The intravee is ok - I believe it's the Alpine unit that's slow in reading info. Go to the intravee forum, there are tips on setting things up to go more quickly. I 'only' have 16GB on the iPhone...
I found that what suits me best is to set up plenty of playlists - one to suit exactly the mood I'm in. One quick scroll and it's set up - then I have it go random.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #63955 14th May 2011 7:28pm
dan_uk_1984
Short vid of DAB and Intravee in action, excuse my random button pressing...
Post #64042 15th May 2011 4:45pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
looking good!!
Post #64043 15th May 2011 4:53pm
EVOeng
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Quick question for you; how did you overcome the charging problems as I understand the Alpine 420i cannot charge anything close to a 4S.
Also, with the 420i is an an actual iPod lead or just supplied with a 3.5 mm jack?
Best,
Post #88894 25th Oct 2011 5:51pm
