![]() | Home > Technical (L322) > B1311-96 Clock Module - Fault Code |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 ![]() ![]() |
That looks like a page from a LAUNCH code reader is that correct? |
RS2000CUSTOM Member Since: 25 Apr 2013 Location: The Black Country Posts: 137 ![]() ![]() ![]() |
Certainly is
Does the clock work? if so, clear the DTC and investigate if the clock ceases to work or the DTC comes back. This relates to the analogue clock, not the actual timekeeping in the BCM/GEM. |
Yep I have tried to clear but the DTC remains Analogue clock appears to keep great time and also when I initially set the correct time the analogue clock adjusted itself as expected 2009 - L322 5.0 S/C Autobiography |
So "Clock Module" is just the analogue clock ?
Yep, that's it. You could try a battery disconnect but the chances are that'd create more DTC's.
Tell me does the analogue clock keep time with the digital time on the headunit? If so what happens if you up-grade the headunit to aftermarket etc
The IHU is used to input the time into the IPK - its the IPK that is the time master, without any correction from the IHU, it'll just keep ticking along. I've had the analogue clock re-sync a few times, never really looked into it but I suspect it's related to voltage drop during cranking causing the I-BUS (single wire, pretty much like LIN) to drop out or possibly the IPK forces a re-sync if it detects dropped comms.
[quote="RS2000CUSTOM"]
Certainly is Just for interest sake what is the model number ? |
It is a Launch X431-EuroPro 4 2009 - L322 5.0 S/C Autobiography |
Very nice Scan tool ....not much that won't do. If i had more money I'd have one myself. |
Have tried many different scan/code readers for my "Day Job" and the Launch for me is the best for what I need it to do I have been a self-employed mechanic for close on 20 years and it is impossible to do day to day jobs without a suitable scan tool 2009 - L322 5.0 S/C Autobiography |
So, did you find the answer to this B1311-96 - Clock Module ?
Well according to posts on here it is the analogue clock on the centre console As mine is keeping correct time and alters time setting if required then I not going to do anything about it I will be living with the code as it not causing any issues 2009 - L322 5.0 S/C Autobiography |
