![]() | Home > Maintenance & Mods (L322) > L322 Roof Bars Options? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
No experience of anything, but on your last pic above, there is a door shut one mounted further back, so it looks like you aren’t limited to door shuts, as is your concern.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
In the last pic that's viewed from the front door.
OMG…. Clearly the morning coffee hadn’t kicked in …. I’ll get my coat 🤣
grayst01 Member Since: 08 May 2022 Location: Glasgow Posts: 105 ![]() ![]() ![]() |
Gary
Have you got a link for them?
https://yogi24.co.uk/en_GB/c/Range-Rover/1351/1/default/4
Which model are they? It lists 3 for the L322.
I'm sure mine are the Aero, I had them powder coated from the Silver/Alu... mine only came specific for the fixed mounting points in the roof. 1 bolt each into the roof.
They're very affordable so, I'll contact them and check.
Yes, they were a decent price |
RR_05_US Member Since: 25 Jan 2022 Location: up north Posts: 15 ![]() ![]() |
Hi,
I had no issue with noise. I had to adapt the bars with a locking nut so they didn't just all fall apart when fitting to the car. Went for the aluminium, so they would be lighter when fitting.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 909 ![]() ![]() ![]() |
I have Thule bars on my 2011 car which I remove when not using them, no complaints when using it to carry my roof box ( which is a big one ) , rated 75kg load but I have probably been nearer to 100kg once or twice and no issues !
@garyRR
