Home > In Car Electronics (L322) > Steering Wheel Buttons on 02 L322 |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
The rotary coupling is the 'clock spring' behind the steering wheel, the switches work on a resistive ladder principle (voltage divider) so you will get a different voltage output dependent upon which switch is pressed. Any poor or broken connection will obviously affect the output and therefore the intended action. |
12th Aug 2022 8:37pm |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 |
Thanks for the reply Phoenix, does this mean if there is bad contacts or broken buttons it could effect the sound system?
12th Aug 2022 8:59pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7823 |
Using the buttons on the dash should eliminate the steering wheel buttons…. To a large extent… not sure what will happen if they are connecting and shouldn’t be.
12th Aug 2022 9:36pm |
Yeah, that's what I was asking about . The DSP amp has been working but I have only the left side working and no volume control on the headunit. This is why I'm heading down the steering wheel buttons channel
12th Aug 2022 10:30pm |
To eliminate the steering wheel / clock spring, you could just disconnect it on the steering column side for testing. If no change (probably a battery disconnect, just to be sure) then it's not the steering wheel buttons or clock spring and you can look elsewhere. |
12th Aug 2022 10:40pm |
Thank you, I went out to the Range Rover this morning went to start, dead battery I said golly gosh and went for the battery charger so I’m guessing battery drained overnight Was either caused bye the rotary Coupler or the DSP amp.
12th Aug 2022 11:57pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Have you checked the head unit volume control (same as the on / off button) ?.
13th Aug 2022 8:09am |
That’s just what I didn’t want to hear 😕 I will have a look at the volume pot on headunit in the morning, but for now I’ve put her on a trickle charger, I’m not sure where the power drain is coming from.
13th Aug 2022 8:44am |
