Home > Off Topic > Can you free these broken screws?
pld118
Hi,
Does anyone have a workshop set up that could possibly grip 2 snapped, possibly seized (head snapped off) M4 x 40mm screws that are stuck in this type spring clip?
Have a non LR car that has a grille I had to remove for maintenance work. The grille is held on by 3 of these spring clips. 2 of the clips I had to drill the heads off because the pozi drive heads had gotten chewed over time. Now I can’t get the remnants of the screw out of the 2 spring clips.
Any advice welcome.
Thanks.
[/u]
Post #639149 10th Aug 2022 6:01am
Are the bolts sticking out the back of the clips to any extent?
Post #639153 10th Aug 2022 6:45am
Baltic Blue
Do you have a decent bench vice ?
Rig it up as a press, put a larger nut behind the bracket and push out the remaining screw with a centre punch.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #639158 10th Aug 2022 8:04am
mpirie
Get a Dremel with grinding stone onto the corner welds.
Mike
Post #639163 10th Aug 2022 9:33am
gettingold
Ez out normally does the trick.
https://www.halfords.com/tools/hand-tools/...6OEALw_wcB visiting from www.rrsport.co.uk
Post #639173 10th Aug 2022 11:08am
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
have you got a picture of the ones that need sorting new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #639175 10th Aug 2022 11:17am
dhallworth
PM me some pictures and I'll have a look to see if it looks doable.
Doesn't sound bad from your description.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #639191 10th Aug 2022 1:48pm
pld118
Thanks very much to dhallworth who very kindly extracted the screw remnants in jig time… well, if he can do what he’s done with a SC, this was never really going to challenge him (as it did moi) 😂👍
Post #639884 16th Aug 2022 9:13pm
dhallworth
No problem Smile
Shame there was a weekend involved or you’d have had them back next day!
Post #639888 16th Aug 2022 9:47pm
