Home > Maintenance & Mods (L322) > Snowfoam - am I doing something wrong?
Vogue Owner
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Java Black
I believed that Snowfoam was a revolutionary way of cleaning your pride and joy but I don't seem to be getting any benefit from it!
I follow the recommendations , 2" of concentrate and rest of warm water , coat the car and leave for 10 minutes then jet wash off.
Problem is that it doesn't seem to even get the old dirty rain water droplet marks off?
All it seems to me is just an additional procedure to be done for nothing during cleaning ?
Am I doing something wrong?[/i] CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : L322 Range Rover
GONE : 2007 MITSUBISHI OUTLANDER
GONE : SAAB 9-3 VECTOR SPORT
GONE : BMW M3
GONE : SIERRA COSWORTH
GONE : LOTUS CORTINA
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #63912 14th May 2011 10:54am
dan_uk_1984
It looks good, and is fun to apply. If only it smelt good then it would be a sensory extravaganza.
It's no good for dirt that is "stuck on" although it will loosen it. It will remove dust and dirt that has settled in the car, but I've found that's about it.
You can stick a little car shampoo in the bottle too if you like and mess with the mix until you have convinced yourself it's working! Thumbs Up
D
Post #63915 14th May 2011 11:05am
Vogue Owner
So Dan it's as I thought - just a gimmick that's fun to apply but that's it! CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #63916 14th May 2011 11:06am
mzplcg
No, it's absolutely not a gimmick. 10 minutes may be a bit long to be fair but what it's doing is loosening all the small dirt particles, the ones which will produce the swirls if ground into the paintwork with a sponge. The pressure washer should then remove these before you touch the surface with a wash mitt.
If you have hard water spotting from previous washing then you need to dry the car more thoroughly. No amount of snowfoam will remove chalk & limescale.
Foam should not be allowed to dry so take that as your guide for rinse time. If you let it dry it makes matters worse by acting like a soapy glue which holds on to the dirt.
Dom.
Post #63918 14th May 2011 11:19am
dan_uk_1984
I wouldnt say it's a gimmick, for fear of being hunted down and killed in my sleep. Snow foam lovers get quite upset when you say things like that!
Post #63919 14th May 2011 11:20am
dan_uk_1984
As per mzplcg, maybe your car wasn't dirty enough!?
Post #63920 14th May 2011 11:21am
Personally IMHO I think it's a gimmick.
You can't beat a proper 3 bucket lambswool mitt wash by hand.
I've tried all sorts of things over the years and nothing beats some elbow grease Discovery 4 HSE
Post #63925 14th May 2011 11:58am
Vogue Owner
Excuse my ignorance but was exactly is a 3 bucket wash? CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #63928 14th May 2011 12:27pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
2 buckets of water and car shampoo and then 1 bucket with warm water to rinse the mitt between every panel. Minimises the risk of having grit on mitt and then causing swirl/scratch marks. FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #63929 14th May 2011 12:47pm
claud
United Kingdom 2018 Range Rover Autobiography TDV6 Corris Grey
Snow foam works if you use it frequently (once a week) on cars which have a small amount of dirt.
Best approach is to wash the car with a sponge or brush at the start of a season with your favoured shampoo and apply a good quality wax.
Then each week jet wash your car to remove dust and dirt. Apply the snow foam, leave for 5 to 10 minutes. Rinse off and then apply a rinse aid such as Autoglym AUTO GLOSS RINSE. Leave for 5 minutes then rinse off.
Remove droplets with a soft squeegee or a blower, then use a micro-fibre mitt or cloth to wipe off.
The secret is to do the above before substantial amounts of dirt build up. If that happens then you will need to use a shampoo and brush or sponge to remove the grime. 2018 Range Rover Autobiography
2010 Land Rover Freelander XS
1959 Series II
1950, 1952, 1954. 1955, 1957 Series I
1952 Minerva Ambulance
Post #63966 14th May 2011 8:01pm
BRUNBERG
United Kingdom 2006 Range Rover Vogue SE Supercharged Bonatti Grey
Dom.
I agree completely. May I ask the OP which brand of snow foam you are using????
I have been detailing cars for many years and get great results from both the valet pro and Meguiars snow foam. Many products produce foam which has little or no effect on paint contaminants.
Are you applying through a pressure washer or hose attachment such as the Gilmour foam master II?
Post #63969 14th May 2011 8:06pm
Vogue Owner
I have Autobrite super snow foam used with a pressure washer CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #63977 14th May 2011 8:32pm
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
its most certainly not a gimmick - if used correctly
you should not 'pre wash' the car - if wet the foam does not have enough time to 'dwell' as it runs off
i use Raquel's snow foam (pm if you want details) and add about 1/2" megs gold shampoo
i use my RR offroad and it removes mud/crap with no problem
Post #64129 16th May 2011 10:13am
nick h
Dom.
+1
Post #64130 16th May 2011 10:14am
nick h
+1
autoglym rinse aid is superb!
Post #64131 16th May 2011 10:15am
