Home > Maintenance & Mods (L322) > Side Steps - Captive nuts gone...
Superspoons
Hi all,
Nearly there putting my Supercharged back together but have an issue with fitting the side steps back.
The captive nuts at the front and on the inside of the 'box section' under the drivers seat gave way when I removed themdue to be rusted out back in May. Bit of pig to get the steps off but that now leaves me the problem of how to attach them back...
I've tried Rivnuts but they just don't grip when compressed/flattened like Rivnuts do. I've got a feeling I may have to weld the bracket up there which is a pain if I ever wanted to look under the sills covers again, but I can't see any other way of getting the step securely attached to the L322.
Any other ideas anyone? Gavin
https://www.youtube.com/@ChallengingClassics
Post #639082 9th Aug 2022 5:59am
A couple of ideas, I expect you will get a few more....
You could make a plate with captive nuts, cut out a section of the sill and weld the plate in, sounds easy in theory but would need very precise positioning, either make a template or use the side step to line up the new plate. welding it in would be a pain as well because of access...
Have you tried aluminium rivnuts, they squash easier and grip better, they do need some form of rustproofing when used in steel though... Thumbs Up Pete
Post #639084 9th Aug 2022 7:21am
Superspoons
Thanks Pete - Yes, I had considered welding a plate in as a last resort but its a bit drastic. Good point about the Ali Rivnuts - I'll look to order some Thumbs Up
I was also thinking of making a 'U' shaped plate up and welding it to the side step and then drilling through both sides of the chassis sill and sending a bolt through from one side to the other to secure it. Gavin
Post #639088 9th Aug 2022 8:48am
If you try to clamp through both sides of the box section sill I think that might just keep bending both sides in, maybe a larger hole in the outer sill and a smaller one in the inner sill and use the large hole to put a bolt, with a decent size washer through the smaller hole which you can then secure with a socket and extension through the large hole.... if that makes sense... You could plug the large hole afterwards if needed.... Pete
Post #639108 9th Aug 2022 1:19pm
Can't remember if it was the front or rear captive nuts that went on me when removing the side steps, but there was a big hole in the rail nearby. I was able to get a nut and washer over the hole and then run a bolt up. Just enough room to get a spanner IIRC. It eventually had enough grip to self tighten without a spanner. Not ideal, but a quick fix. .
Post #639118 9th Aug 2022 2:53pm
Superspoons
I went for a mixture of that and my finger stuffed up in the hole - its all done now and I'm about to post it all up on my main thread.
Thanks all for the responses Thumbs Up Gavin
Post #639306 11th Aug 2022 3:37pm
