![]() | Home > Technical (L322) > Upper Tailgate Replacement with Donor |
This is a job on my list, I've a replacement tailgate, completely stripped including glass - off to be painted, I found a small amount of corrosion under the lower edge seam sealant which has been ground back and treated.
p2ddy Member Since: 06 Aug 2022 Location: Winchester Posts: 2 ![]() ![]() ![]() |
How easy is the glass to remove and refit? I found some previous posts saying that it is possible to get the wiring loom out and back in but they are just a bit ‘fiddly’ and takes a bit of time and patience…
I have a 'tame' (i.e. family member) Autoglass fitter, sorry, 'technician' but TBH once the interior & glass trims are removed I could do it with a cheese wire in about 15 minutes. Clean it up with a 'toffee wheel' or similar, change the harness over, bond the screen back in, home in time for tea & medals....
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 92 ![]() ![]() ![]() |
Good evening everyone I purchased a RR Vogue SE 2007 and the first job I did was replace the upper rear tailgate from a donor car.
It sound more work but it's better IMO to remove the glass, it makes everything else easier - and it's the way it was done at build... |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 895 ![]() ![]() ![]() |
I’ve also done this job, exactly the same method as Tiprat has described.
