Home > Maintenance & Mods (L405) > Third row seats retrofit L405
Billy.sg
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
Hi All,
I would be ever so greatful for your knowledge and advice on a peculiar issue I face. I have seen quite a few examples of this done on L322’s but do not fancy the rear facing arrangement due to carsickness issues.
Would you know if seats, D-pillar belt and cover from L494 Sport or Discovery 5 or discovery sport can be retrofitted in to a 2013 - 2018 L405?
What is needed apart from the obvious seats, bolts under-carpets, remaining boot space cover C-Pillar covers, seat belt with pretensioner (winding mechanism). Anything else I may have missed.
Any retrofitting instructions guidance, steps and procedures to pay attention to / follow
Of course some might say safety electronics.. I would however need this for only a few short distance local trips for one adult in the third row.
Any advice and guidance you may have will really help.
This is quite urgent as my passengers arrive this Sunday.
Thanks a Million in advance for all your responses Suzuki Gypsy MG410W 94 -Tata Grand Telcosport / Sierra 92 -Nissan X-Trail Aventura 07 2.2D -Honda CRV ES 01 S4 1.9L -Honda CRV ES-L 07 VTEC 2L -L322 Vogue 04 V6 3L -L322 Autobio 11 V8 4.4L - L405 Autobio 16 V6 3L -L320 Autobio 71 V8 4.4L -XC90 InscriPro 21 V6 2L EV PLUG-IN HYBRID -L405 Autobio 19 V6 3L -Velar P350 HSE Dynamic 21 2.2D -L405 Vogue SE 63 V8 4.4L
“WYSIWYG.... Do I still need a catchphrase?!”.
Post #638599 3rd Aug 2022 4:35pm
to my knowledge no one has done that conversion here on the forum..
i can see many problems like how does someone get into the back..yes the seat tips forward but its still an effort to climb in.
lack of height would also be a problem.
if you do the conversion please let us know how you got on. ... - .- -.
Post #638614 3rd Aug 2022 7:39pm
Ive never seen anyone do it sir...
Post #638629 3rd Aug 2022 10:38pm
Billy.sg
Thank you Stan & Craig! I do appreciate the quick replys.
Would Anyone know the sizing of the seats and frame that holds them
There is a seat set from an LR3 on flea bay with a electronics. Switches carpets, seatbelts /w pretentionsers going for about £300.00
I was hoping that if someone knows what the dimensions are, I could try and do a calculated hack.
Dont want to buy them if they are not going to work at all, thanks
Best regards
Billy Suzuki Gypsy MG410W 94 -Tata Grand Telcosport / Sierra 92 -Nissan X-Trail Aventura 07 2.2D -Honda CRV ES 01 S4 1.9L -Honda CRV ES-L 07 VTEC 2L -L322 Vogue 04 V6 3L -L322 Autobio 11 V8 4.4L - L405 Autobio 16 V6 3L -L320 Autobio 71 V8 4.4L -XC90 InscriPro 21 V6 2L EV PLUG-IN HYBRID -L405 Autobio 19 V6 3L -Velar P350 HSE Dynamic 21 2.2D -L405 Vogue SE 63 V8 4.4L
Post #638666 4th Aug 2022 11:01am
Snowy90 L322
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
Appreciate its not a 405 but might be worth contacting this guy to see if he can help at all?
https://www.fullfatrr.com/forum/topic64147...seats+boot
Post #638668 4th Aug 2022 11:09am
Imagine what might happen in a case of a collision?
Third row seating is usually crash tested no?
Post #638671 4th Aug 2022 12:02pm
agreed..
theres also the insurance implications.. ... - .- -.
Post #638677 4th Aug 2022 12:50pm
Exactly! At least the old Overfinch 6/7th seat that we’re CE marked and certified for use with that model!
So, can you check if there is like an IVA test? I’m guessing that would give piece of mind to both user & insurance company… JLR use IVA tests a lot for prototype vehicles… 👍
Post #638698 4th Aug 2022 4:01pm
Martin2
Or a much simpler, safer and cheaper solution...
https://www.sixt.co.uk/ford-car-hire/ford-galaxy/#/
Very Happy MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #638701 4th Aug 2022 4:15pm
LT
As above, rent a vehicle with more seats.
Anything is possible with time, skill and money. However, I predict, as have others, that you’ll have serious insurance grief and the conversion will require bodywork modification that will affect the resale value.
That’s assuming that you can find someone to do in time anyway.
Post #638702 4th Aug 2022 5:11pm
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
I'm just sitting here drinking Bourbon... thinking Jack, you need to give this guy hope - just because you would like to see it!!!
The L322 guy (link from @Snowy90) used the lashing points - which are still in the L405...
Run a piece of angle iron each side front to back to be affixed under the lashing points. You would need angle iron for the vertical leg to give you rigidity in a crash. Flat bar would deform easier...
Holes could be drilled into the Angle Iron, and the seat frame - which I assume is all 1 piece could be bolted to that.
You lose the 'boot' obviously, and depending on the placement of the seats - the spare well becomes your foot room.
Some thoughts if you will allow me -
The same set-up facing the rear would work better. The rearward leaning back seats and row 3 would be opposing one another - but the upper tailgate slopes in a good bit. You could go min recline on row 2 and bolt row 3 up against it. I think you have more legroom flipping it around. I don't like his wooden frame - I would want to go with steel... In the event of a front end collision - the 2nd row seats are rated to keep back some luggage weight so that helps keep the 3rd row from ending up on the 'bonnet'.
Do you know a lot of Jockeys or Gymnasts that are needing a ride? Or is your name Jobiden and you transport a lot of kids?
It would take 2 days and 3lbs of bacon grease slathered on my Fat American @ss to insert/extricate me to/from this forward facing hell on wheels. I could probably drop that to inside an hour for rearward facing...
As a child of the 70's - look at these guys - there is no car-sickness, there are no seatbelts - just the open road and ADVENTURE!
In the big picture - what's £300 compared to the opportunity to have the Only L405 "in the Known Universe" with a 3rd row?!?!?
I say GO FOR IT!!!
Sorry - just saw how old this post is... I hope you did it and can provide Pics! 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #701190 30th Sep 2024 11:15pm
