Home > Technical (L322) > Boost pressure actuator Bank1 and Bank2 4.4TDV8 |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
I may be chasing a problem that doesn't exist, but would be good to know what they mean. The engine runs ok though. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
2nd Aug 2022 8:59pm |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 |
I've been wondering the same thing. The controller output seems to bounce around considerably, as if the boost actuator is sticking or is slow to respond. |
3rd Aug 2022 2:44pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
That's a sticking actuator, there is a strategy in the programming that tries an 'unstick' - which seems to be working for now, I'd investigate further before it becomes an inconvenient problem. |
3rd Aug 2022 5:44pm |
Thanks for that, question is which one?
3rd Aug 2022 9:22pm |
Whichever one you're measuring, which appears to be bank 1 from the graph labels- from another resource
Checking the rose joints of both would be a good diagnostic & preventative maintenance first step. |
3rd Aug 2022 9:42pm |
Rose joints on these?
3rd Aug 2022 9:51pm |
Yep, like this
4th Aug 2022 6:19am |
Thanks. I suspected the VGT but will look into all of them. This would explain the sluggish behaviour (at times)
4th Aug 2022 8:03am |
It very much depends on how the software is written, with Ford based stuff, I would expect bank0 and bank1, however, with aftermarket diagnostics sometimes this is translated to 1 & 2. The only way to be 100% certain is to disconnect one (the easiest one to get to!) and see which values are affected, don't go by DTC alone as they could well have been transferred verbatim. |
4th Aug 2022 1:25pm |
Is that the actuator in question or is it the CSOV shown in the previous diagram? |
4th Aug 2022 9:16pm |
That's just an example, it's possible of course (although less likely) that the control ring is sticking but you won't know that until you check the link rods and rose joints. |
5th Aug 2022 6:23am |
Probably need to be clear which part we are talking about before school gearing it could be smaller parts relating to it. |
5th Aug 2022 6:56am |
Haven't had a chance to look at it, but how many actuators are in the distribution path? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
8th Aug 2022 9:49pm |
One per turbo plus the vacuum operated deactivation - but that is not relevant to the operation of the VGT's.
8th Aug 2022 10:26pm |
