![]() | Home > Maintenance & Mods (L322) > Wheel nuts: loose caps |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Just spent the best part of 2 hrs swapping my wheels over, made almost impossible by the frickin pathetic not fit for purpose scissor jack (the handle bent making it impossible to use |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35504 ![]() ![]() |
OE scissor jack is cr4p, i have a 6ton bottle jack in mine as a addition to the scissor jack and a nice high lift trolley jack at home..
Something else that puzzles me is how vague the handbook is about jacking and wheel changing. It doesn't stipulate if you should drop the car and lock in access height, normal or off road before jacking. It seems to me that when you jack the car up you are mostly lifting the air springs to the extremes of articulation till the wheel actually lifts off the ground, no easy task!
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 869 ![]() ![]() ![]() |
I'd be careful with the caps. They become distorted over time with undoing and doing (usually air guns screw them up). Eventually they'll get so out of shape the brace will no longer go on, without being hammered. I scrapped three of mine recently for that reason. My Previous RR's!
Best practise is to Lock it in OFFROAD using rear door open as in the mode the suspension is already FULLY EXTENDED (no suspension drop possible) and if jacking from under suspension using trolley Jack the wheel comes up of ground real quick. Will not work with Scissor jack though as bodywork will be to high. Halfords sell cheap trolley jack that works a treat - use it every week ![]() |
I also have a 2 tonne trolley jack with a stupidly short hand and a very short lift. Rubbish from screwfix.
