Home > Maintenance & Mods (L322) > 3.6 TDV8 Temperature Sensor/ Thermostat Issue
this_is_anarchie
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Hi All,
I have a 2007 3.6 TDV8 that has been having an issue for a little while. When I start the car, temperature (on the instrument cluster dial that is) rises as normal, is fine for about 10 mins, then drops to nothing for another 10-20 mins. Then generally comes back and stays normal. Is this likely to be a sensor, if so which one? Car is otherwise fine and drives fine.
Any help would be appreciated
Thanks
A
Post #638414 1st Aug 2022 11:30am
garyRR
I had this once on a Leon. Exactly the same issue - one minute it was reading temperature fine, the next minute it was reading 0, the next it was back to normal again.
It was the coolant temperature sensor so, that would be my bet. 2015 Range Rover Autobiography 4.4 SDV8
Post #638456 1st Aug 2022 8:58pm
