Home > Technical (L322) > Slight Judder under braking, more so from higher speeds |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
A number of things to consider.
29th Mar 2019 6:25pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
As said above ^ |
29th Mar 2019 6:50pm |
Thanks Craig. Cheers
29th Mar 2019 7:34pm |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 824 |
Thank you Richard and Craig - I think I last changed the discs about 18k miles ago - How long should they last in normal conditions?
29th Mar 2019 11:37pm |
Take the car for the highest speed run you can and then simply put your hand on the rear wheels and if one is considerably hotter than the other then bingo! Thats the problem calliper... |
30th Mar 2019 12:38am |
Will do - That's great, thank you Craig |
30th Mar 2019 7:43am |
Check with the back of your hand not your fingertips from the rim inwards. (ask me how I know ) Cheers
30th Mar 2019 8:46am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Use a leather gardening glove on first pass to avoid a burn Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
30th Mar 2019 10:21am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 815 |
I am getting a similar juddering feeling through the steering wheel when pulling up to traffic lights pretty sharpish on the brakes fairly hard, I don't notice it at higher speeds, only when I am slowing down to a halt
30th Jul 2022 3:30pm |
Biffa4444 Member Since: 09 Jul 2019 Location: Ipswich Posts: 3 |
I've had the same problem, turned out to be a sticking caliper which caused the disc to heat up and warp. New discs, pads and calipers on the rear and its all good |
31st Jul 2022 9:57pm |
BenRK Member Since: 19 May 2020 Location: County Durham Posts: 164 |
Exact same problem for me. Gradually got worse until it was noticeable to everyone in the car when braking
1st Aug 2022 11:05am |
