Home > Maintenance & Mods (L322) > Violent wheel wobble
Andy
Whilst driving to work on the motorway this morning at 70, the front end started to act strangely. Best described as a rapid wheel wobble. It only does it whilst I’m negotiating a steady left. If I’m driving in a straight line or a steady right, it’s fine.
It seems to start when I go over a bump. It can be something as simple as a cats eye that starts it off. When I straighten the wheel it stops.
I assume it’s suspension related?
2010 3.6 TDV8 for info 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #638146 29th Jul 2022 7:48am
dingg1
I freshened up the front end on mine, new control arms, ball joints, drop links and track rod ends and bushes, had a steering wheel wobble at about 65mph.
One drop link was shot,, as was track rod end, same side, transformed the car into feeling brand new again, no wobbling or clunks over potholes.
Whole kit only about 200 quid. Thumbs Up
Post #638156 29th Jul 2022 8:52am
Andy
I’ve just checked my MOT and there’s two advisories on it for lower suspension ball joints showing slight wear. I wonder if it’s that? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #638157 29th Jul 2022 8:56am
Phoenix
Check your wheel nuts are tight first.
Post #638187 29th Jul 2022 1:28pm
Andy
They are. Torqued to 140 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #638188 29th Jul 2022 1:31pm
Phoenix
Time to get the front end up on axle stands then!
Don't forget to check the track rod ends and the tie rod inner ball joints for free play along with everything already mentioned. Oh, and the wheel bearings.
Post #638192 29th Jul 2022 1:40pm
