Home > Technical (L322) > Park assist module
DEEBEE(060)
United States 2012 Range Rover HSE 5.0 V8 Orkney Grey
Park assist module
2012 full fat HSE supercharged, 5l US spec. Where is the park assist module, used to be behind rear fuse "box". Mine houses air suspension module. Thanks
Post #638124 28th Jul 2022 11:34pm
bishbosh10
Should be on the left hand side of the boot as you look at the car from the rear.
http://www.fullfatrr.com/gallery/albums/us...%20PDC.JPG
from https://www.fullfatrr.com/forum/topic46410.html Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #638177 29th Jul 2022 11:51am
DEEBEE(060)
Thanks, found it. Now to investigate whether it is the module or more likely a sensor.
Post #638555 2nd Aug 2022 10:59pm
chdavis
2012 Range Rover Autobiography 5.0 SC V8 Galway Green
If the button doesn't light up when you put the car in reverse, or it is delayed, you have yourself a bad module. If you get the long beeps when the PDC engages, you probably have a sensor issue. 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
2020 Tesla Model 3 Performance, 2013 Mercedes-Benz G550, 2008 Ferrari F430, 2007 Volkswagen Touareg V10 TDI
Post #640685 24th Aug 2022 3:28am
