Home > Technical (L322) > Steering column control does not work |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
By all means try a battery reset, you never know...
24th Jul 2022 9:14am |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 689 |
It's also worth taking the "pleatherette" flexible top shroud off the column and checking the electrical connectors to the motors
24th Jul 2022 4:58pm |
Raggen Member Since: 24 Jun 2022 Location: Whangarei Posts: 4 |
Thanks. Based on your help I have been able to manually adjust steering wheel position
24th Jul 2022 11:31pm |
I am confused.
25th Jul 2022 12:43am |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Have you checked that you are getting voltage to the motors? you say the control signals are there but you need to put a voltmeter across the power terminals on the motor and see if there is any activity when the move command is issued. |
25th Jul 2022 6:13am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
I presume you have to checked as to whether or not the auto steering wheel function is still in operation and hasn’t been deleted by a previous owner. Deleted mine years ago, never missed it. Much better than the risk of the mechanism failing. |
25th Jul 2022 7:40am |
@Phoenix Measured across 2 terminals on the in/out motor, no voltage when signal applied
25th Jul 2022 10:19pm |
I've just looked at the wiring diagram (below) it appears the motors have a ign. switched live supply via the seat relay & a ground together with a control wire, probably a LIN so expect to see a fluctuating voltage in the 7-10V range.
26th Jul 2022 6:26am |
