![]() | Home > Technical (L322) > Drivers door won't open from inside or outside |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
IIRC there is a way in if you can open the rear offside door. A small bung should be visible in the rear face of the front door, outside of the top outboard lock mounting bolt. Remove that and it gives access to the mechanism. You can then use something like a small allen key to pop the unit open.
Deano322 Member Since: 23 Mar 2020 Location: UK Posts: 6 ![]() ![]() ![]() |
Hello there,
