Home > General > Should i?? Shouldnt i??
Garymahoo
Hi All. New to this and never had an RR before but ive been offered a late 2011 Tdv8 Vogue in white. Same owner for 7 years and only 63k which looks like 3-5k per year going by Mot history. Also had an oil service this year.
It seems to have the design kit with the squarer rear bumper with the square exhaust outletss
The owner has passed away hence i have first dibs.
Ive only actuallly seen it in the passing and will get home for a proper look on Friday but realistically is this something i should be looking at????
Im not skint but neither am i Daddy Warbucks.
What i am asking is what am i averagely looking at to keep one of these on the road?
2nd car so hopefully in the region of 5-6k miles per year.
Ive been reading lots of posts on this fantastic forum all week and swing between "I must have this thing!" And
"What the blinking flip am i thinking?"
Help
Gary
Post #637348 19th Jul 2022 9:15pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Go for it! Razz
I've had a Rangie for thirteen years now and only last year moved up to a 4.4TDV8 from twelve years in a 3.6TDV8. Wish I hadn't waited so long to get the 4.4! Mine's only got 51k on the clock and I love it to bits.
If you're in the south of the shire, I'd happily offer to come and check it out with you, as I know them fairly well.
As for running costs, excluding tax and fuel, mine's been cheaper than the wife's A3 on maintenance in the past year, primarilly because I've started to work on it myself (oil change etc). Never lifted a glove on the 3.6. Whistle The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #637351 19th Jul 2022 10:04pm
Go for it, you can always sell it if it doesn't behave....
Beware, you will get hooked on it.... Thumbs Up Pete
Post #637356 19th Jul 2022 10:51pm
Garymahoo
Haha. To be honest on this forum i never expected anyone to try to put me off.
Today i am swinging towards a go for it attitude. As suggested i can always sell it again Smile
Actually north east of the shire.
Home on Friday so will be crawling about looking for oil leaks amd rust no doubt.
Thanks for suggestions.
Post #637360 19th Jul 2022 11:14pm
Phoenix
Get some temporary insurance, take it for a drive for a couple of hours - give it some beans and hold it there for a few miles.
When you get back, check for the scent of hot, leaking coolant. If OK and there was no surging when lifting off the throttle with a fully warm engine then you're pretty much good to go - assuming there's no horrendous amounts of corrosion, tyre wear isn't 'odd' and the diff's didn't growl on every tight-ish bend. Oh, work the suspension as well, check the range change functionality and operate the park brake a few times....
Post #637362 19th Jul 2022 11:27pm
Garymahoo
Actally the temporary insurance is a really good idea. Im going to ask for an Extended Sunday drive. £36 for a days insurance is good value if its not everything it should be. Bow down
Post #637364 19th Jul 2022 11:38pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
You have to go for it, hearts and heads in turmoil with should I / shouldn't I. Ive been their twice and each time bought one. Brilliant car, 4.4 TDV8 is incredible BUT they have the propensity to bleed your wallet dry at an alarming rate without warning. There is no doubt it's something you just have to do, like marriage go into it with your eyes wide open and thereon after keep them half closed.
Good luck, enjoy! BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #637368 20th Jul 2022 5:08am
Sandyt
They are really reliable if you look after them there might be a few niggles if it has been sitting around and as Haylands mentioned you can always sell it - expect to see photos before the end of the weekend and welcome to the club Thumbs Up
Post #637369 20th Jul 2022 5:23am
JayGee
Depends how much the seller is wanting for it and if you 'want' a white L322 (not to everyone's taste) 2012 TDV8 Vogue (L322)
Post #637377 20th Jul 2022 8:52am
DrRob
All good advice above. As said, check for oil leaks underneath (at rear of engine under tray) as the oil cooler gaskets leak on most at some stage. You can also smell it ff bad. Look in coolant header tank for any oil contamination.
Check its not rusty underneath too. Some I've seen are shocking for their age (boat launchers usually).
You have MMP in Dundee not too far away. Could you arrange for Mike there to inspect it on your extended test drive? Worth an hour of his time. Inspect, read codes etc. It's what I'd do Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #637381 20th Jul 2022 9:42am
JayGee
If you have a specialist near then 100% get it inspected so you know what you are in for. 2012 TDV8 Vogue (L322)
Post #637397 20th Jul 2022 11:21am
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Gary, if you don’t go for it you will always regret it. In terms of running costs, on your suggested mileage your looking at a service once a year plus the odd consumable. Think all in £3k pa for tax, insurance, servicing and odds and sods. Investigate a warranty too. In your shoes, I’d be in like a shot for this one.
Andy
Post #637400 20th Jul 2022 12:04pm
Garymahoo
Wow. Thanks for the advice folks.
I knew i was in the wrong place to get spoken out of this.
Price wise i cant see a cheaper one for the miles and its thousands cheaper than anything on autotrader (which seem metal high) so thats no issue and the colour and wheels look very smart as i remember.
Hopefully i can use my sunday drive and go to Aberdeen but I'll be coming from North so Dundee is a fair hike.
All comments very much appreciated.
Love this forum stuff. Who wouldve thought i could spend a couple of hours reading about the benefits of replacing 2 small o rings that i dont even know if i need haha.
Gary
Post #637425 20th Jul 2022 4:35pm
Garymahoo
Ok folks.
Had a drive and it drives brilliantly.
But. Suspension light is on amd says only normal height available.
On my 2nd run today it went bing and brought up a Censored of faults.
Abs dtc adaptive suspension, park brake.
Possibly that connection or earth inside the drivers wing?
Im pretty happy with the price and i have a local budddy who is not concerned as he has had a couple of Range Rovers
Its not a rusty bus. Bit on the tailgate which seems standard. Scorpions all round wearing evenly, no smoke on giving it a heavy acceleration from standing or from driving.
Little oil at the back of the engine but not a lot.
No oil in the coolant.
Did i miss anything.
Family seem chuffed.
I still keep asking myself if im mental??????
Post #637813 25th Jul 2022 3:54pm
Garymahoo
Post #637814 25th Jul 2022 3:55pm
