![]() | Home > Technical (L322) > DPF Red Warning ! Please help |
The codes with B are battery related so can be ignored... The P040D code relates to an exhaust temperature probe... If this reads low temperature then the engine ecu can up the fuel rate (like a choke) and this fills the DPF with unburnt fuel... Does your car smell like a 1970's ice cream van? |
NeilTDV8 Member Since: 29 Mar 2019 Location: notts Posts: 11 ![]() ![]() ![]() |
No i have never noticed any strong exhaust smells buddy |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Change out the 4 hoses for new silicone ones as step 1 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I have got some hoses (4) on the way should have them for Wednesday ! |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Thankfully many problems on the 4.4 TDV8 tend to be the same ones so, it makes diagnosing quite easy. The usual culprits (in order of easiness and least expense): 1. MAP sensor. Usually gunks up every few thousand miles, which can result in false readings to the ECU, resulting in over-fuelling or false demands for exhaust gas recycling. It's 1x T20 screw and can be cleaned with electrical contact cleaner. Also clean out the hole with an ear bud or some paper towel (job takes about 2 minutes) 2. Silicone charged air and inlet manifold hoses (as already discussed above). Sometimes holes can be so small or fine cuts, the only way to see them is by taking off the hoses, having a good look and squeeze with a torch. Also check the lower hoses. The left side turbo lower hoses can quite easily be inspected by undoing the glowplug bolt (like you would when doing a service) and removing the airbox. (Job takes about 30 minutes to check and replace hoses) 3. The plastic union which joins the throttle body from the left charged air hose with the metal clip. The green double lipped rubber seal begins to collapse over time and causes intake leaks. Characteristics are soot/oil deposits around this area of the engine bay and on the paddles inside the throttle body. Permanent fix is a new hose which is £175. You can try a temporary fix with a high temperature sealant, putty or gas specification PTFE tape. (5 minutes to replace this part or 30 minutes fannying around trying a temporary solution) 4. The exhaust gas temperature sensor. It's not expensive itself but does involve removing a load of bits to get to it Very rarely is the DPF error message the DPF, its usually a result of one of the four above. 2015 Range Rover Autobiography 4.4 SDV8 Last edited by garyRR on 18th Jul 2022 10:50pm. Edited 1 time in total |
Thanks for the in depth reply buddy, i will keep you posted what i end up doing to sort it ! |
