Home > In Car Electronics (L322) > Venture Cam Dock Voltage - Only 1V |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
I think I have another board somewhere, it charged and operated OK but wouldn't transmit video, I'll connect that to the battery pack and see what happens, it does sound like the Dock needs to see some sort of voltage at the charge pads before it'll do anything. |
13th Jul 2022 1:54pm |
RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 207 |
Yep..... I'm hoping that the dock just hasn't come to life because it can't see a camera.
13th Jul 2022 2:13pm |
I found the following in the WSM in the wiki; (although I have no codes showing relating to the cam)
17th Jul 2022 5:08pm |
Sorry matey, not had time to look for the spare PCB yet - working yesterday plus gearbox oil & filter change plus some unplanned maintenance on No.2 Son's L319 today....
17th Jul 2022 5:35pm |
Oh there is definitely nothing to say sorry for!!!!!! Enjoy dinner!
17th Jul 2022 5:42pm |
I discovered I have the system description, in the locations file for 'DVD and Venture Cam' in the WSM. Under battery charging it states;
17th Jul 2022 6:58pm |
Yer, I've seen that too - it depends upon whether the charge control is done by the base or the camera, if you go onto the Venturecam screen, it shows 'venturecam docked' and the charge status, now unless there is some way for the dock to monitor both by the charge pins, it suggests to me that the ID of the camera, charge state and docking state is done via the IR link.
17th Jul 2022 7:10pm |
I would read it as being that it's controlled by the dock, but it's a bit open to interpretation.
17th Jul 2022 7:38pm |
I'll block the IR port and dock the Venturecam, if nothing happens then it has to be the return, if not bidirectional link. I think it does need both as even with a Venturecam in the dock but not latched, nothing happens. |
17th Jul 2022 7:51pm |
I've received a reply from Pat at GAP which includes; "...and its on the MS CAN. Problem I see right from the get go is that a 2008 unit will not work on a 2010 car. The CAN bus are using a different message format. You need to get the proper unit for your model year" Which is 'unfortunate' but at least it's an explanation as to where it went wrong! I'll start keeping an eye out for a 2010 dock! Cheers Richard 2010 Range Rover Autobiography TDV8 Santorini Black 2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone] 2003 Range Rover HSE Oslo Blue [Gone] 1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone] 1990 Camel Trophy 127 (Workshop Vehicle) [Gone] 1989 Camel Trophy 110 (Workshop Vehicle) [Gone] 1998 Camel Trophy Freelander (South African Team Vehicle) 1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone] |
18th Jul 2022 8:16pm |
I think 'message format' is a bit misleading, the CAN frames haven't changed at all - that would be a change in protocol! It's possible that the addressing is different, i.e. the messages sent to the dock contain info that the earlier dock cannot act on - that also doesn't explain the difference in the Venturecam's themselves WRT terminal voltage at the charging pads.
18th Jul 2022 8:26pm |
Yep, I presumed it to mean the addresses.
18th Jul 2022 8:57pm |
