Home > Maintenance & Mods (L322) > Bilstein rear air spring failure
Page 1 of 3 123>
GraemeS
Australia
Today a Bilstein rear air spring that was less than 1 year old burst along its seam. The vehicle was travelling slowly at off-road height towing an empty box trailer with nothing in the boot. Has anyone else had problems with Bilstein air springs or is this an isolated failure?
I have refitted the original air spring that was kept as a spare. Apart from getting a replacement for the burst one, I'm nervous about the other one which was replaced at the same time.
Post #636309 8th Jul 2022 7:35am
dhallworth
That's worrying as I fitted a pair of Bilstein rear air springs to my car as well.
Post #636320 8th Jul 2022 9:43am
dingg1
Aerosus aren't much better, had one fail on the front after a day or two, the bag had slipped out of the top clamp creating a massive leak....
Post #636323 8th Jul 2022 10:03am
GraemeS
Australia
The other side 11-month old Bilstein just split open after selecting off-road height while driving over uneven ground to my hose to remove the dry mud from the wheels and from under the guards. Either both were from a bad batch or Bilstein air-springs can't take off-road height other than very infrequently. Either way, I'm very unimpressed.
Post #637060 17th Jul 2022 5:31am
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
This worries me, Just proactively replaced the rears recently. Was it sourced locally?
In the process of replacing my front bilsteins that are around 5 years old (with BWI and original AMK compressor (proactively)) SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #637064 17th Jul 2022 8:47am
GraemeS
Australia
They were purchased from Island4x4 who are looking into the 1st failure and have now been notified of the 2nd.
Neither show any signs of having been anywhere near fully extended which isn't possible anyway with shocks fitted, which are Bilsteins anyway. On both a small section of the top layer has torn away from the underlying layer in an area that is inside at normal height but probably on the outside at off-road height. I suspect that the torn area is the point of failure and the spiral split top to bottom has simply torn along the threads. Regardless of whether manufacturing or design fault, I'm very surprised that they both burst within 10 days of each other having been fitted for 11 months, although in recent weeks off-road height has been used quite a few times to get through a very boggy section on my lane so perhaps the recent extra use has been the trigger.
My front struts purchased as Bilstein struts arrived fitted with Dunlop air-springs.
Post #637066 17th Jul 2022 9:07am
GraemeS
Australia
I've just spotted that MY07+ 3.6 TDV8 (not the 4.4/4.2 petrol) and all MY10-12 use a different rear air-spring to earlier vehicles. MY07+ TDV8 uses a different rear shock which might have a longer extended length which might be the same as the MY10-12 CVDs. Today's failure occurred while at off-road height travelling slowly over light ruts which may have been the final straw if the air-springs have been operating outside their design criteria if Bilstein haven't properly allowed for more suspension droop than earlier models, if that is indeed the reason for the difference in spring and shock part numbers.
PS: The vehicle has very recently been on a hoist for its annual registration inspection whereby the shocks would have been fully extended, the first time with these air-springs fitted.
Post #637078 17th Jul 2022 11:51am
ffrr14
I have done the same, would you have the part numbers by any chance? what is the resolution? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #637177 18th Jul 2022 6:25am
ffrr14
What I purchased from Island4x4 2 x RKB500240 SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #637178 18th Jul 2022 6:34am
GraemeS
Australia
The Bilstein part number is 40-240732 which is marketed as an alternative to the LR part number RKB500240.
I suspect that they are too short and due to the proximity of the 2 failures to each other that the damage was probably done when the vehicle was on a hoist very recently as part of its rego inspection, last done with the original LR air-springs.
I will now only fit the LR genuine rear air-springs. I hope to have discussions with Island4x4 tonight, wanting the air-springs to be accepted as unsuitable and that Island4x4 will offer a reasonable upgrade to genuine springs, which they sell at the best price of all resellers that I can find.
Post #637180 18th Jul 2022 6:48am
ffrr14
I believe I will have the same issue also keen to understand how to take this forward SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #637181 18th Jul 2022 6:55am
GraemeS
Australia
I intend asking Island4x4 tonight to order in a pair of LR air-springs as I need them urgently as I'm having to remove the 20A suspension fuse every time the vehicle is parked so that only 1 corner, not 4, has to be pumped-up on restart.
I suspect that Bilstein would have to acknowledge a design fault before any reseller would contemplate replacing/crediting ones that are still intact, which might take a while. Mine were purchased less than 12 months ago and Island4x show 12mth warranty on their web-site so there shouldn't be a warranty issue with mine. You might want to refer to mine in communications with Island4x4 but perhaps wait a day or so to see what the response is to both mine failing.
Do you still have your old ones?
Post #637183 18th Jul 2022 7:09am
ffrr14
I do have my old ones, goodluck with your conversation tonight SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #637202 18th Jul 2022 1:08pm
GraemeS
Australia
The only response so far is that they're in touch with Bilstein and that Island4x4's previous air-spring failures were soon after a vehicle had been on a hoist as the crimps get pulled. The ends didn't pull off and this would only occur if the shocks were removed or the shocks were too long for the springs. Vehicles are regularly lifted at 1 or both ends to fit new tyres which also fully extends the shocks.
No comment on my urgent need to get hold of a pair of LR springs, which I don't want to order via the web-site as I want a credit for the failed Bilsteins to go towards the cost.
Post #637255 18th Jul 2022 10:00pm
ffrr14
Thanks for the update Graeme, did the original springs fail also? I replaced rear shocks and springs with matching Bilstein set not so long ago. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #637263 18th Jul 2022 10:38pm
Page 1 of 3 123>
