Home > Technical (L322) > Front electric seats stopped working.
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hey guys more seat problems. The front seats have just stopped working for no reason. I've checked all the fuses, battery reset etc etc to no avail. Yet the lumber support buttons all work, just can't move seats forward and back or the headrests and back rests. Also the electric steering column adjuster not working either so i presume they are all interconnected.
Ideally I'm hoping it's an easy fix as we are going to the Highlands in it in a few weeks time and missus is going to be driving it too when i get her insured on it. But me being 6ft 2" with seat right back and back rest far back she can't reach the steering wheel and barely touched the pedals. Any help would be appreciated.
Post #637099 17th Jul 2022 3:26pm
RJPotts
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Have you checked all the plugs under the seat? If it's not a loose plug I think you may find the seat ecu has expired.
Cheers
Richard 2010 Range Rover Autobiography TDV8 Santorini Black
2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone]
2003 Range Rover HSE Oslo Blue [Gone]
1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone]
1990 Camel Trophy 127 (Workshop Vehicle) [Gone]
1989 Camel Trophy 110 (Workshop Vehicle) [Gone]
1998 Camel Trophy Freelander (South African Team Vehicle)
1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone]
Post #637148 17th Jul 2022 7:10pm
garyRR
Check the fuses first.
If it is the seat ECU, don't worry, there's normally plenty on ebay for about £40 and it's a 15 minute job to change one.
Remove 4x bolts on the seat rails, tilt backward. Underneath you'll see a black plastic cover with some pop in trim clips on (iirc there's 2). Remove those and remove the cover then hey presto, just unplug and swap the seat ECU over.
Might be trying anyway, as it's quick and relatively cheap? 2015 Range Rover Autobiography 4.4 SDV8
Post #637149 17th Jul 2022 7:20pm
Barmybrummie
Thanks for that guys. I'll try the fuses again just in case when i get time. They only stopped working when i fitted the deployable sidesteps, and another thing I'm going to try when i get time is to swap over the plugs from the steps back to the ECU under the fusebox and see how that works. If not I'll go down the new ECU under the seat route. Nice to know they are cheap.
Post #637160 17th Jul 2022 8:07pm
