![]() | Home > Technical (L322) > Restricted Performance - Turbo Actuator Technical Bulletin |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
For comparison, here is mine.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1299 ![]() ![]() ![]() |
You need long arms to reach it from the top or take engine cover off the bottom. |
I got to it from the top to replace the wiring plug on mine
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 ![]() ![]() ![]() |
I'm impressed you managed to get your arm down there. I took most of the skin off my forearm but I could get my hand to it.
Vacuum pump which feeds (a few) vacuum switchover valves, if you had issues with the vacuum pump, you'd notice it on the brakes first, that said, I have had vacuum leaks on other components (engine mounts for example) causing issues with other components on the low volume vac line. You'd need a tee piece and a vacuum gauge to properly diagnose or confirm no vac. leaks / proper vacuum being attained. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
The solenoid can fail. LR have a simple test procedure for the solenoid/valve operation although I don't recall the specifics. |
Yep, the test is fairly simple, it's a PWM signal from memory but can be checked by applying 12VDC and checking for flow - assuming the vacuum is within spec. |
The one that I've seen is something along the lines of allowing the engine to idle for a number of seconds, disconnecting the solenoid electrical connector, increasing revs to around 1000 - 1200 rpm then reconnecting the solenoid electrical connector with specific results, demonstrating that the valve does or does not operate as it should.
Bit confused. Are you suggesting that there is a solenoid or an electrical connector to the CSOV or do you mean the vacuum pump? |
There is a solenoid valve that controls the amount of vacuum supplied to the actuator, the vacuum is supplied by the vacuum pump, the same one that provides vacuum to the brake booster etc. |
Great. Thanks. That makes sense. Where is the solenoid located?
This is your vacuum control system.
You must be very close to spotting the solenoid as it is near the top of the front of the engine. Note that there is another solenoid so be sure to trace to the correct one.
Latest error is:
