Home > Technical (L322) > Faults from IID Tool |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35447 |
if thats your first scan then clear the faults and check in a weeks time.....its possible that some are historical...
8th Jun 2016 10:45am |
Mcnallykev Member Since: 19 Jul 2015 Location: Lanark Posts: 172 |
Thanks Stan. Not my first scan I'm afraid I will have a look at the Wiki |
8th Jun 2016 10:49am |
ah, ok..i get regular faults come up like the speaker one and a tmc one but it all works ok.. ... - .- -.
8th Jun 2016 10:55am |
Davidmudley Member Since: 26 Dec 2021 Location: Surrey Posts: 80 |
Did you ever get to the bottom of these errors? I have the same and am struggling to find the air quality sensor replacement part (or number). I haven't started on the speaker circuit issue yet. Thanks. Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR |
13th Jul 2022 11:33am |
Hi David.
13th Jul 2022 12:09pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
I have these and believe they are not real faults but spurious glitches. The air quality sensor is a BMW part AFAIK and easy to replace if you need the recirculating AC feature ( if it is even faulty ) 2012 TDV8 Vogue (L322) |
13th Jul 2022 12:38pm |
I think I can live with the errors, but I went to have the air con checked today and they could t get it running cold despite it being gassed up and suggested there may be an issue somewhere that an error code might be able to pin point. Hence thinking it might in some way be affecting the air con circuit from getting properly cold.
13th Jul 2022 12:53pm |
The sensor only works when the AC recirculating feature is used and has no effect on the normal AC operation. If you have no cooling after a regas it’s likely the compressor is the fault (RCV valve / common issue). There is a recent thread explaining DIY replacement if you are up to it. 2012 TDV8 Vogue (L322) |
13th Jul 2022 12:58pm |
Thanks JayGee, I'll get investigating further. Out of interest would you expect the compressor to spit out an error code of some sort? Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR |
13th Jul 2022 1:12pm |
https://www.fullfatrr.com/forum/topic63831.html
13th Jul 2022 1:17pm |
13th Jul 2022 1:19pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 |
Does sound like a new compressor job to me. I had same. Full gassed, no leaks. New compressor, job done Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
13th Jul 2022 3:42pm |
Who looked at this for you? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
13th Jul 2022 3:43pm |
ATS Euromaster, so not who I would consider experts in diagnosis. Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR |
13th Jul 2022 6:33pm |
