![]() | Home > Maintenance & Mods (L322) > Rear screen washer pipe size |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
My rear screen washer has blocked again for the umpteenth time.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 335 ![]() ![]() |
<deleted> |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1236 ![]() ![]() ![]() |
This got me thinking about my last MOT, I watched the whole thing and chatted to him as he had never MOT'D a range rover!! He never checked the rear screen wash but the guy was very thorough so I would agree with the comment from RangeRoverL322.
I’m no expert, but believe that any feature fitted as standard , such as rear screen wiper, washer, headlamp washers etc. can be given as an advisory or Fail, depending on issue, if they don’t work correctly.
I have been ringing around to get a new non return valve,
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 395 ![]() ![]() ![]() |
I've just had mine apart as no water was coming out - 1.6mm sounds right. Mine was jammed up at the two jets so cleaned it out with a safety pin and now ok.
I have just cleared mine using hot water and a syringe.
Replaced my arm, one way valve and blade over the last few months to get a clean sweep without streaks. Still can't get the jets to put screenwash exactly where I'd like it but it's better than it was. 2012 TDV8 Vogue (L322) |
The beauty of using the syringe full of hot water to force water through the motor and jets , you can adjust the nozzle with a needle whilst squirting water through without the wiper keep moving.
DanRRL322sc Member Since: 16 May 2022 Location: Bedfordshire Posts: 55 ![]() ![]() |
Point of note Mike - some of the 911 models do come with a rear wiper, on some iterations you had to tick the delete option on the order to avoid it |
