Home > Technical (L405) > Tailgate won’t open… |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1381 |
One thing you might consider is to call LR Assist or LR Customer Relations, even if you don't have a LR warranty on the car. When I was stranded in a field one evening, with LR Assist long expired, I called LRA for some advice to be given to the recovery person and was given helpful and practical advice which solved the problem. The operatives at LRCR latterly have just been telephonists that read off the website, but in the past it was possible to get access to someone from the factory with expert knowledge in the relevant area. It will cost little to try, and your fallback will remain getting the car transported to the nearest dealer. Only Range Rovers since 1988 |
10th Jul 2022 12:28pm |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
Thanks CS, I called LR Assist (the AA apparently), they couldn’t help but recommended that I contact the AA Technical Department as I am a member. I did this but they couldn’t come up with anything helpful.
10th Jul 2022 5:10pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8230 |
The tailgate backup solution is to stop folk getting locked in the boot, not for assisting entry if the lock fails...
10th Jul 2022 5:54pm |
