Home > Technical (L322) > L322 4,4TDV8 Coolant leak |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
2.5x18mm Viton o-rings have been used at the coolant fitting at the oil cooler which might also be suitable for that connector if the housing ID is close to 18mm. |
9th Jul 2022 11:09pm |
Mariusses Member Since: 09 Nov 2020 Location: Berkshire Posts: 20 |
Thanks GraemeS. I believe thats the right size 18mm. Thats what it says on the connector NW 18-30.
10th Jul 2022 1:01pm |
Or the inscription actually tells me the size is 30mmx18mm Viton o-rings ? |
10th Jul 2022 1:59pm |
That would have to be 18 x 3.0 if it is the o-ring size.
10th Jul 2022 8:44pm |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
These pipes are not too expensive from main dealer. |
19th Jul 2022 9:08pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
Kind of on the same subject, could someone show me an engine diagram with the common leaks circled on the 4.4 TDV8? Mine loses about 100ml every 4,000 miles and in my searching around the engine so far, I haven't spotted anything pink yet, including around the thermostat housing and oil cooler. 2015 Range Rover Autobiography 4.4 SDV8 |
20th Jul 2022 9:09am |
I have a small leak on the fitting on top of the thermostat housing.
20th Jul 2022 9:14am |
The thermostat housing doesn't look overly different to the one on the 3.6 TDV8 which is one I've replaced before. Not an overly difficult job - just requires some persuasion to get the lower seal free on the unit and I found it easier to cut the 2x hoses going to the heads and replace with new than fanny around trying to get them off gently. 2015 Range Rover Autobiography 4.4 SDV8 |
20th Jul 2022 9:21am |
It’s just the push fit pipe on the top. But need to buy complete unit to get that pipe. |
20th Jul 2022 9:42am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Have you had a pressure test done on it? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
20th Jul 2022 9:51am |
Not sure a pressure test would help, as I already know there's a small leak somewhere and just need to find it. It's of no urgency - would just be good to get some hints at other things to look at which are common on the 4.4 TDV8.
20th Jul 2022 9:55am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3072 |
A pressure test would pressurise the cooling system with the engine cold and switched off so you could look for leaks.
20th Jul 2022 11:03am |
I bet it's an O ring somewhere. I'm convinced mine is doing the same but no obvious leaks...
20th Jul 2022 1:21pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1206 |
For you guys thinking of doing a pressure test, I had an old expansion cap that I managed to take apart and fixed a small tube in the centre. I connected it to my compressor and instantly saw where my leak was. A cheap idea for you handy folk. |
20th Jul 2022 2:31pm |
