Home > Technical (L405) > Rear anti roll bar leak posssibly
Jon555
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Just noticed a few drips on the floor under where the rear anti roll bar is. Rear drivers side
The ace fluid level look fine no loss
If it has a leak can the anti roll bar be refurbished or is new the only option ?
If so where is the cheapest place to order one
Any advice appreciated
Post #588820 25th Mar 2021 7:58am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Check your pipes feeding the anti roll bar, they’re quite prone to corrosion and can spring a leak.
Post #588977 25th Mar 2021 10:07pm
wealy
did you ever sort this?
Post #636395 8th Jul 2022 3:20pm
