Home > In Car Electronics (L322) > MP3 to USB
Shaunj69
England 2012 Range Rover Autobiography 4.4 V8 Zambezi Silver
MP3 to USB
Good day FFRR
How do you up load MP3 files to a USB stick?
I have a 2012 4.4 TDV8 autobog, I have tried playing MP3 music thought my USB via a USB stick, But the car keeps saying corrupted.
Is there a correct way of uploading the files to the USB? The stick i am using is a exFAT 128mb.
Many thanks
Post #632937 26th May 2022 10:52am
GraemeS
Australia
Format as FAT or FAT32.
Make sure that there aren't any zero length files as the firmware doesn't check which then corrupts the playing sequencing.
Post #632938 26th May 2022 10:55am
mjdronfield
Yeah, exFAT is ok on more modern cars, but a bit too modern for the L322….
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #632942 26th May 2022 11:27am
Shaunj69
Many thanks
I will see if that haelps
Post #632948 26th May 2022 1:00pm
JayGee
Play from a usb stick is very slow to access tracks and search. Much better using your phone and Bovee 1000 2012 TDV8 Vogue (L322)
Post #633076 27th May 2022 7:06pm
Shaunj69
Good morning
took your advise and got a blue tooth unit, but not the Bovee but the INVERY with the iphone plug. Plug,Play and forget. Thumbs Up
Post #636089 5th Jul 2022 7:15am
JayGee
Looks like the same unit as the Bovee 1000 but can't tell if the internals are updated? Keep me updated if the connection is stable as mine disconnects when I get a phone call through the LR BT system and I have to physically disconnect and reconnect the unit to get it to pair again on my iphone. 2012 TDV8 Vogue (L322)
Post #636150 6th Jul 2022 9:09am
RJPotts
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I've also got an Invery unit and have found it stays connected after calls.
The only 'issues' I've had are that it sometimes forgets which track was playing at the end of the previous journey (& reverts to the beginning of all tracks alphabetically), that's related somehow to how the phone is used between journeys I'm sure but haven't had a chance to experiment and narrow it down. I have also found, once only, that it refused to play anything at all, that was solved by restarting my phone.
Cheers
Richard 2010 Range Rover Autobiography TDV8 Santorini Black
2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone]
2003 Range Rover HSE Oslo Blue [Gone]
1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone]
1990 Camel Trophy 127 (Workshop Vehicle) [Gone]
1989 Camel Trophy 110 (Workshop Vehicle) [Gone]
1998 Camel Trophy Freelander (South African Team Vehicle)
1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone]
Post #636153 6th Jul 2022 9:49am
JayGee
Richard - do you have an iphone or android? The Bovee stayed connected with my previous android but not the iphone. 2012 TDV8 Vogue (L322)
Post #636154 6th Jul 2022 9:57am
RJPotts
I have an iPhone SE2 2010 Range Rover Autobiography TDV8 Santorini Black
Post #636157 6th Jul 2022 10:44am
RJPotts
Further to the above......
I had a call in the car earlier, whilst listening to music from my phone. When the call ended the music resumed very quickly and at the point it had been at before the call. 2010 Range Rover Autobiography TDV8 Santorini Black
Post #636203 6th Jul 2022 10:12pm
JayGee
Just ordered the Invery so will test and report back. 2012 TDV8 Vogue (L322)
Post #636236 7th Jul 2022 11:16am
Shaunj69
Good afternoon all
Just an update. No real issues upto now, But yes it will revert back to the 1st song after you have switched the car off. Still if that's all that is going to go wrong, then happy days.
Oh the only other thing i have found out is to get the best out of the car sound is to turn all the sound affects off on the phone. The sound is very good, but then i do have the 1200w KH logic 7 HD.
Post #636375 8th Jul 2022 1:38pm
JayGee
The autoplay feature on the Iphone drives me Censored . I ended up making a 5min silent track and named it AAA so it at least I can't hear anything. I also don't like the fact that the autolock can't be disabled when it's connected to the car like it can with android. I have real buyers regret over my Iphone 13 pro and will be definitely going back to android and sooner than later. 2012 TDV8 Vogue (L322)
Post #636376 8th Jul 2022 1:47pm
bishbosh10
Could I please request a link to the Invery item?
Is it this one?
https://www.amazon.co.uk/Airdual-Interface...amp;sr=8-3 Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #636381 8th Jul 2022 2:27pm
