Yesterday my lower glovebox became impotent, it just wouldn't stay up.
Quite well timed as this evening I was taking the gloveboxes out (whilst retrofitting a venture cam). A prod through the hole for the stay seemed to indicate the issue but it can be more clearly seen below;
 | Click image to enlarge |
The little bit of foam rubber is all that holds the stay across, so that it catches on the edge. If your lower glovebox has developed a droop then you'll probably find the piece of foam rubber is still in there, just pushed to one side. With the glovebox lowered you should be able to fish it out, glue it & get it back in place, through the hole without having the faff on of taking the glovebox out.
Just thought it may be easier for someone to sort when they can see the issue in a pic.
Cheers
Richard 2010 Range Rover Autobiography TDV8 Santorini Black
2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone]
2003 Range Rover HSE Oslo Blue [Gone]
1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone]
1990 Camel Trophy 127 (Workshop Vehicle) [Gone]
1989 Camel Trophy 110 (Workshop Vehicle) [Gone]
1998 Camel Trophy Freelander (South African Team Vehicle)
1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone]
