Home > Maintenance & Mods (L322) > Bleeding brakes advice |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
How can air get trapped in the ABS block unless the system has been opened around it? - and I assure you, pressure bleeding with 'brake pedal assist' will get any air out of the system, wherever it is. ABS blocks default to open channels from the master cylinder to the outlet pipes with no control input, therefore, even on opened systems, it is a trivial matter to ensure an air-free brake hydraulic system. It's something I've been doing across a range of vehicles, JLR included, for many years.
2nd Jul 2022 3:22pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
I think I'll add it to the list of jobs for Glenrands next week. I did another gravity bleed on the rears this morning but saw no air coming out but then it wouldn't would it as it would travel back up the lines to the MC. 2012 TDV8 Vogue (L322) |
2nd Jul 2022 3:44pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1258 |
You don't half talk a load of twaddle. You really do know everything about everything. I won't be reading anymore of your Gaff. |
2nd Jul 2022 4:05pm |
Oh well - perchance you do read this 'gaff', tell me what you think happens in your view of fluid dynamics?
2nd Jul 2022 4:22pm |
